Author: Subject: Rover V8 3.9 Spark plug
darrens
posted on 14/4/13 at 08:35 PM Reply With Quote
Anyone recommend a plug type/brand for the above RV8 injection
Ta
posted on 15/4/13 at 07:43 AM Reply With Quote
The original fittment was Champion RN9Y or RN9YC
The best conventional plugs for a road RV8 engine are NGK BPR6E or PBR6ES Gap setting is 0.9mm or 0.035"
For longlife Platinum NGK PFR6N before fitting remember to gap to 0.9mm The hex size is smaller but that isn't significant.
For longlife Irdium (best plug for LPG) NGK BKR6EIX-11
Again gap requires closing down to 0.9mm and smaller hex.
[Edited on 15/4/13 by britishtrident]
posted on 15/4/13 at 01:00 PM Reply With Quote
Is that the same using a trigger wheel setup and Ford coil packs?
darrens
posted on 20/4/13 at 01:18 PM Reply With Quote
Cheers fellas
