Author: Subject: R1 IVA map
Chaddy
posted on 20/4/13 at 08:11 PM Reply With Quote
R1 IVA map
Hi All. has anyone got a Power Commander map they could send me for a 2005 R1, tried to map mine today and failed.
adithorp
posted on 20/4/13 at 09:44 PM Reply With Quote
I can e-mail the one I used if you u2u me your address. It worked on my 06 R1 but it all depends on you air box and exhaust whether it works for you.
http://jpsc.org.uk/forum/
Chaddy
posted on 21/4/13 at 07:00 AM Reply With Quote
Hi Ady
It is your map I am using as a base map, I have done the breather mod and have a standard Yamaha exhaust with Exup as far as the cat. The air box is custom made to fit the space. The readings were way out so I minused all the readings, got the idle OK but fast idle was way out, got to the point where it hardly ran then gave up. Test is on Wednesday!!!
Dave
Coopz
posted on 21/4/13 at 08:43 AM Reply With Quote
Dave,
U2U me your email and I will send you the map I passed with, although I can't guarantee it will work with your set-up.
My setup:
06 R1
Caterham exhaust with new cat
Pipercross 'sausage' Airfilter
AIS blocked off (I was finding with it installed I couldn't get the lambda reading down)
Cheers coopz
Chaddy
posted on 21/4/13 at 10:11 AM Reply With Quote
Hi Coopz
U2U sent, any help is much appreciated
Dave
Coopz
posted on 21/4/13 at 10:48 AM Reply With Quote
All sent bud, let us know how you get on.
Chaddy
posted on 21/4/13 at 11:17 AM Reply With Quote
Thanks Coops, will do
