<<  1    2    3  >>
Author: Subject: bedford cf2, what would you do?
mark chandler
posted on 28/4/13 at 09:19 AM Reply With Quote
My thinking was 'make the best of what you have, throw a few toys at it and see if you can squeeze a bit more enthusiasm out of the existing engine'. This would be the least complicated way forward. 250 quid on a carb, 200 on a piper cam (they actually supply a cam kit for this engine believe it or not), get a better exhaust (better as in better not 'halfords rocketship funnel', the usual boy racer bits and bobs, but without expecting miracles
Wasting your time with a better cam in a low compression engine, for £250 you could fit bike carbs.
hillbillyracer
posted on 28/4/13 at 01:16 PM Reply With Quote
What would I do in your position? You're keeping the van whatever but want more go on a budget, happy with petrol power so I'd be looking at buying some ropey but sweet running RWD car for as little as you can find & transferring it's engine & box to the van. Being careful/lucky with what you buy you could break/weigh the rest in & have the hardware for very little money leaving a bit to spend on getting it all to work. If you could get something running on it's own management you'd have an improvement in power, refinement, economy & reliability.
This would in effect be the same idea as fitting the Essex V6 as was planned but starting out with much more modern hardware.
You would need the fabrication gear/skills to make mounts, clutch gear linkage etc & somewhere to work on both it & the doner car. Also you'd need the skills to do the electrical side of things* & need a bit research on what cars it's practical to isolate the engine management as much as what would physically fit in the space but given a complete working car to take the wiring, modules etc from certainly possible. My mate is a electrical/dairy engineer by trade & only automotive knowledge from him messing about with his own stuff but managed to remove all the gear from a SAAB 9-3 to make it all run fine in another car on the SAAB management without much problem.
*Or a good mate who can!!
P.S. Good work on keeping the old thing on the road despite what anyone may tell you that should be done with it.
Volvorsport
posted on 28/4/13 at 01:32 PM Reply With Quote
does the engine slant over ? , if so which way ?
www.dbsmotorsport.co.uk
getting dirty under a bus
timbedford
posted on 28/4/13 at 04:16 PM Reply With Quote
Originally posted by scudderfish
So you've already mentally allocated a budget of at least £450. You must be able to get a decent Ford engine, gearbox and fit it for that.
My remaining budget 'after scam' is more than that, but I'm treading carefully because i'm loathed to throw the rest away as easily. I have to confess that I don't have the time, the space, the equipment or the skills to do the work myself (I realize that I shouldn't even be on this site but was drawn here by the mention of a cf2 with manta GTE engine in it), so I'm looking to commission whatever I do from someone who has the means to do it professionally.
timbedford
posted on 28/4/13 at 04:23 PM Reply With Quote
Cheers Hillbilly racer. Its a tough job being a Bedford owner hahaha, you either love them or hate them and I personally love them, especially in original panel van mode as mine is ( is not a camper conversion).
Volvosport, its not a slant... Its an Opel engine. The Vauxhall slants were in pre84 CFs.
Simon
posted on 28/4/13 at 05:38 PM Reply With Quote
Originally posted by timbedford
.......... I don't have the time, the space, the equipment or the skills to do the work myself (I realize that I shouldn't even be on this site but was drawn here by the mention of a cf2 with manta GTE engine in it), so I'm looking to commission whatever I do from someone who has the means to do it professionally.
Don't want to disappoint you, but what you are building and why, are the precise reasons you're welcome on here - this forum may have started out as a RC Locost forum but I think it's developed into a helpdesk for all comers (except those that happen to crash thru the Halfords chav dept).
As for you not having the time, skills, equipment or space; guess what, neither did most of us. But, we wanted to achieve something so we put our minds to it. I think you'll find one or two from here who may be local and willing to have some input if you are willing to put in the effort yourself.
Thing is, once you've developed the skills, you'll be able to put them into practice with every project (and you'll save a hell of a lot of money into the bargain).
I'd get yourself on a welding course at the very least, then start saving to build the van how you want, without compromising.
Simon
MikeR
posted on 28/4/13 at 05:50 PM Reply With Quote
low compression petrol engine as standard - what about a small turbo? need to be careful around the carb but it could be the cheap solution your looking for with very few mods.
tango man
posted on 28/4/13 at 05:51 PM Reply With Quote
i had a beddy cf back in my bike racing days ,early 80s had a 2.2 ventura engine in i think , it flew, used to do a ton on motorway got there pretty sharp aswell , bloody horrible to drive though , dangerous aswell but alot better than austin j4 i had previous
timbedford
posted on 28/4/13 at 08:12 PM Reply With Quote
Thanks for comments and the clarification about the nature of the site... Makes me feel a lot less like I'm somewhere I shouldn't be.
As for a turbo.... I did read somewhere that low comp engines are perfect for turbos, so I think I'll investigate that too.
Cheers all. Been reading past threads on here today. There's a LOT of knowledge on here. Glad it came up in my search.
Volvorsport
posted on 28/4/13 at 09:37 PM Reply With Quote
has it got a getrag ?
if so , i think the saab motors will fit but dont quote me on that ...
should be quite respectable after that.........
timbedford
posted on 28/4/13 at 10:03 PM Reply With Quote
It has a 5 speed ZF (Zahnradfabrick) box.
I think, for now, I'm going to stick a 32 36 on it, change the inlet and exhaust manifold gaskets (exhaust gasket blows and I would imagine the inlet probably has a little bit of a leak by now), see if that makes much of a difference... If it feels like a slight improvement I'll venture on with other toys... Better exhaust, better ignition, maybe a turbo (that would be quite interesting) etc etc, and if not I'll consider buying a 90's petrol rwd manual vauxhall with at least 2.0litres, and switching the innards over.
Still interested to know if Nat @ retro power still has the manta engined cf though. Might call them tomorrow.
Ninehigh
posted on 28/4/13 at 10:17 PM Reply With Quote
Linky
I guess those seat will come in useful too
Andybarbet
posted on 28/4/13 at 10:31 PM Reply With Quote
I had a CF2 years ago, it was a 2.3 litre with a 5 speed box, I loved it.
Used to go pretty well but it was only used to lug fishing gear about occasionally so it never had much weight in it.
If your gearbox is the same, mine had reverse where 1st would normally be & 1st gear was back where 2nd would normally be. I had some interesting traffic light starts before i finally got used to it
I remember my dad adjusting the carb fromthe passenger seat whilst i drove it, really handy having most of the engine inbetween the front seats
Good luck with it & keep us all posted on the progress.
timbedford
posted on 29/4/13 at 07:49 AM Reply With Quote
Nice one Andy. When I first got my van it was in a fairly bad way. It had been left to rot by an elderly bloke who couldn't get about anymore. The engine cowl was in the back and it had to be driven with the engine exposed, which was pretty noisy and stank too because the front pipe was rotten through. It didn't have a choke cable properly installed and was in dire need of a carb rebuild. To stop the van conking out when decelerating it was necessary to yank on a piece of wire that opened the choke, then let it go again when it was time to pull off. If I was going to be sat in traffic I had to pull and clip the wire to the gear stick via a heavy duty butterfly clip.
It was more like a horse than a van in some respects.
This also answers the earlier question about why a TDCI is too noisy.. The engine is in the cab and the sound deadening is minimal. A few people in the bedfore owenrs club put TDCIs in. Then found they couldn't hear anything for a week after driving them. There's now a huge amount you can do in a bedford to tackle that.
Mine runs sweet now except for the flatness above 50mph. Below 50 its actually pretty decent for what it is. As long as nobody else wants to pull away quickly from the lights, I can convince myself I've just roared off like a beast, even if a nissan micra overtakes me a few seconds later hahaha, and being rwd it can still bring a smile on wet/icy roundabouts.
The safe and legal way to speed: feels like 90mph, is actually 30mph.
francois2.4
posted on 8/6/13 at 11:54 PM Reply With Quote
hi ,
if you want more power ; you've got many way :
_ make a swapp ( BMW /ROVER / Opel Ecotec / ..... ) but is it legal in your land ?? ( here in France , it ( sadly) isn't )
_make a swapp from a bigger Opel CIH engine ( Senator-Reckord 2.2 / Frontera-Omega 2.4 ) , same Bore as your 2.0 , but more Stroke
( 77.5 and 85 mm versus 69.8 )
_you can also keep your engine and 'tune' it
I am contemplating putting a new 32 36 weber on
that's the first step in your quest of power , ( you can also fit a 38 DGAS , but the 32/36 is a good carb )
you can increase you CR by fitting CIH 2.0S pistons
here is 2 links :
http://www.opelgt.com/forums/opel-engine-performance-modifications/
http://www.opelgt.com/forums/opel-engine-performance-modifications/25925-opel-gt-performance-ideas.html
look for RallyBob work
i think you may struggle to find a manta GTE engine for decent money these days,
yes , they're becoming rare !
but what about an ecotec? way cheaper, tuning parts are available from SBD, Omega gearbox will fit straight up too
Right , or the Getrag 240 from the 1800 SOHC !
and still the same block!
Not at all , Cih are différent of SOHC/DOHC !
Sylvain
[Edited on 8/6/13 by francois2.4]
spaximus
posted on 9/6/13 at 07:34 AM Reply With Quote
The CF engine was always a pile of poo which just did the job. I worked on these for years and although the block is the same the engine that went in the ViVa etc was different in many ways.
Another issue with engine swapping is the CF has a massivly heavy flywheel to keep the little engine going, even the petrol versions had then.
My advice would be to start saving and then when you have enough swap in a Rover V8 from a range rover with a manual box, you will also need a better back axle as they are low geared and drink petrol.
The V6 was a popular swap and did'nt need too much cutting to get in but is under powered to todays engines standard.
francois2.4
posted on 25/6/13 at 09:32 PM Reply With Quote
@ Spaximus ;
you're mistaking !
you tall about Vauxhall engine ; but he has an Opel engine ( CIH 2.0 N )
man can have either Vauxhall or Opel engine on the Bedford ( i'm not sure i write correctelly )
Sylvain
timbedford
posted on 29/9/13 at 09:08 PM Reply With Quote
Francois, thanks for those links about the pistons. I will check those out.
My van...
As an update (its been a while since I started this thread), I went ahead and fitted a 32/36 even though most people I spoke to (both online and in oily workshops) seemed to think it would be a waste of money.
I went ahead anyway and it wasn't an easy fit. Weber claimed it would bolt straight on but in reality it had to be bodged a wee bit as it didn't fit even with the supplied adaptor plate.
Got it on though, and I was immediately pleased that I had done so. When playing with such a tiny amount of power and an unambitious engine, every little helps, and the amount of improvement from this carb was significant. Its still not a rocket ship, obviously, but where I could only hit 80 flat out I can now do 92/93. I can get up long hills at 70mph without losing speed on the way up, and the acceleration is greatly improved at various points on the way to the top.
As an added bonus, the carb adds a nice burbling/grumbling note to the sound of acceleration with the suck of the air filter on top of that. Its a small thing, but its nice to hear it when I press the pedal.
Downsides are that it obviously uses more fuel and it also takes a few minutes to get going from cold. It still starts first time, but for the first couple of minutes I need the choke out plus I have to keep the accelerator pressed lightly down or it cuts out. Can be tricky reversing out of car parks or if I get to a junction immediately after starting. It doesn't seem to help if I sit still with the revs up for a few minutes. It seems to need to get moving. After a couple of minutes it will idle perfectly without cutting out. These are very small prices to pay. I'm really glad spent the money, and also enthused to try something else now... maybe a garret; might look into a megajolt or similar, and pistons as per Francois' suggestion and/or cam.
I'm not looking to get silly performance. I'm not sufficiently moneyed to be upgrading the brakes and handling to cope with crazy speeds, so I don't want to be driving a van that cannot cope with high speed.
A bit more spirit on acceleration is all I'm going to aim for. My van can't really cope with much more than 90mph top end.
Cheers for all your advice in this thread.
timbedford
posted on 1/10/13 at 10:49 AM Reply With Quote
Made enquiries at a local race tuning shop in Sussex area about fitting a turbo. £3000.00 and upwards for the whole job.
Van is worth about £300.00 and downwards...
I believe the phrase is "LOL"
Not Anumber
posted on 1/10/13 at 12:04 PM Reply With Quote
Some of these tuning places seem to think anyone wanting more performance must be a millionaire.
Everything you do should be incremental and reflect value for money.
£ 3000 turbo probably no.
A better Vauxhall engine that will bolt up to the existing bellhousing and would still let you use the Weber you have bought would probably be the next move.
timbedford
posted on 1/10/13 at 12:42 PM Reply With Quote
I must admit I was quite surprised. I knew I'd need a bit of pipework... a better exhaust manifold, but I'd naively looked at the cost of Garrett turbos on ebay (few hundred squids) and imagined I'd be able to get a Heath Robinson bodge job done to fit a second hand / recon turbo suitable for a 2.0 8v engine onto my old girl.
That's an indication of my ignorance and naivety I guess. I imagined the whole lot could be done for a grand or so.
How wrong I was!
Engine swap is out of the question... The distress and loss of vital funds when I attempted that this time last year and got ripped off by a scoundrel means my missus will start swining the frying pans if I so much as mention it.
snakebelly
posted on 1/10/13 at 12:55 PM Reply With Quote
Im not saying that £3k is a reasonable cost but bear in mind that the management if using one of the known brands ie Omex, DTA, Emerald etc could suck up north of £800 of that cost before you even start looking at manifolds turbos etc and of course if someone else is doing the work then the labour will be at least half of that i would think. Have to agree with previous post, a zetec and a type 9, cheap and tried and tested.
Not Anumber
posted on 1/10/13 at 01:30 PM Reply With Quote
I was thinking more straight swap for the Carlton/ Omega version of that engine for £ 200 to £ 300 from a breaker or Ebay seller. The van versions were always low compression so it will be a cheap and easy win for the next stage and will let you build on what you have.
The door is then open for some porting and polishing of the head, a fast road camshaft and possibly megajolt ignition for the next incremental stage.
posted on 1/10/13 at 03:25 PM Reply With Quote
The CF II with the Ascona engine as use in the Opel Blitz version was better than the dreadful Vauxhall Slant 4 but it didn't make the rest of the van any better In the 1950s and early 1960s Bedford held a big share of the van market with good but rust prone CA , the CF did immense damage to the Bedford brand and allowed Ford to come from almost no where to completer sector dominance the brilliant piggy Transit. I have driven many of these vans, even when new CF handling wasn't good I could be kind and say the handling didn't inspire confidence but in truth even driving a straight line demanded constant steering correction.
The only major market that remained for the CF was for specialist body conversions, ice cream vans, mobile shops, motor homes and ambulances, for the sole reason the CF chassis cab unit undercut the equivalent Transits by a large margin.
T66
posted on 1/10/13 at 04:22 PM Reply With Quote
http://www.retropower.co.uk/projects_v8_cf_van.htm
<<  1    2    3  >>
