<<  1    2    3  >>
Author: Subject: Urgent setup problem
Valtra
posted on 6/5/13 at 04:11 PM Reply With Quote
Hi
Got connection between laptop and ecu (Microsquirt) in Tuner studio but now can't get past the opening setup conflict
MAFMAP enabled when MAF is not
what the hell have I done ? I've now disconnected virtually everything from the relay board so that it's basically just a powered up ecu with no sensors attached
How do I proceed ?
"If it looks like it works and it feels like it works, then it works"
robocog
posted on 6/5/13 at 04:29 PM Reply With Quote
What sensors are you using?
MAF or MAP or both?
I'm not that familliar with microsquirt but if its anything like the megasquirt you need to go through an initial setup to tell it what to expect and put some sane values in
Not sure if you got the unit with a pre programmed setup or not ??
if you did get it from a working machine - download the current setup from the ECU and save it with a meaningful name
If its a virgin unit - your going to have to tell it everything it needs to know and get that info on there
Time to dig into the manual and digest (or blag someone local to come over and get it setup...but then wheres the fun in that?)
I know the pain as I knew bugger all about ECU's and fuel injection before I went with Megasquirt - it took lots of reading to sink in for me
Regards
Rob
Valtra
posted on 6/5/13 at 05:17 PM Reply With Quote
MAF or MAP or both?
Regards
Rob
I think I've sussed it .......for now
Valtra
posted on 6/5/13 at 11:07 PM Reply With Quote
Well dunno what I did but it let me add all the sensors to the relay board and didn't throw any woblies when I powered up between each connection.
I tried the starter but it didn't want to start as you say there are probably many settings way way wrong . Various boxes were flashing up on the results chart ... algorithm invalid etc etc
my basic setup is
Fiat Twin cam 1585cc
Suzuki GSXR 600 K6/7 TBs modified to remove secondary injectors and throttles using standard brown injectors which are apparently 225 l at 3bar
Edis with the vr sensorfinding the missing tooth 90degrees (9 teeth) BTDC (how do I set the tuner studio to fire 10 deg BTDC)
GM IAT and clt sensors
Suzuki TPS and MAP
Bosch Fidle valve
Innovate LCI with G5 gauge
Microsquirt v3 (MS2 v3 I think) pre loaded code whatever that means .
Efi Analytics tuner studio
[Edited on 6/5/13 by Valtra]
dave_424
posted on 7/5/13 at 09:17 AM Reply With Quote
For fixed 10 degrees, go to basic setup, then more ignition options, then in the first box select fixed timing, then in the box below labeled "timing for fixed advance" make sure it is 10 (or whatever you want your fixed timing to be)
Dave
scudderfish
posted on 7/5/13 at 09:25 AM Reply With Quote
Don't confuse the angle where the missing tooth is with what the firing position is. 90 degrees is just how EDIS 4 works (it's 50 degrees on my V8). If you remove the connection between EDIS and MS, the EDIS will happily drive the spark at 10 BTDC all day. All MS does is tell EDIS what the timing should be.
Having said that, if you run at 10 BTDC, it will be a gutless pig. 10 BTDC is a default limp home mode. You really should have a spark map that varies dependent on speed and load. My map only has 4 cells with 10 in them, the rest vary between 8 and 36.
Regards,
Dave
Valtra
posted on 7/5/13 at 12:42 PM Reply With Quote
Thanks guys
Once I can get it running tuner studio should be able to shape a suitable map for me , I just need it to cough into life
[Edited on 7/5/13 by Valtra]
Valtra
posted on 11/5/13 at 02:30 PM Reply With Quote
Control algorithm changed this from Maff/Map to Alfa n to clear the conflict coming up on tuner studio now have a loud buzzing that seems to come from either the relay board as if a relay is in spasm or is it just the injectors ?....either way it still won't start . any suggestions ????
dave_424
posted on 11/5/13 at 02:58 PM Reply With Quote
Now that you have changed from MAP to Alpha-N, your tables may well be incorrect, on the fuel load side for Alpha-N you need 0-100, MAP would be different.
To check if it is your injector that is buzzing, put the tip of a screwdriver on the injector body, and then press the end of the handle into your ear, you will soon hear if it is the injector.
Are you getting any error messages in tuner studio?
If possible, you could go back to MAP (were you using MAP/MAF?) use just MAP, and then if there are any config errors, go into tuner studio, communication, mini terminal, then turn ignition off and then back on again and it should tell you what is wrong with your config.
I did have that high pitched screeching noise coming from my set up the other day when wiring it in, can't recall what was wrong though.
Valtra
posted on 11/5/13 at 03:09 PM Reply With Quote
thanks Dave
Just checked and yes there is a momentary high pitched buz from the injector but the overall major noise still comes from the relay board , I could try removing each relay in turn to see which is rattling ?
Valtra
posted on 11/5/13 at 03:20 PM Reply With Quote
there is no control for simply Map just
Map/Maff
speed density
percent baro
Alpha-n
MAF
ITB
where do I go with that ?
dave_424
posted on 11/5/13 at 03:21 PM Reply With Quote
Yep, sounds like a plan.
After some searching, is it low battery, like when you are trying to start a car with low battery and all you get is the fast clicking noise.
That may well have been my problem when I got the buzzing, I was having low battery problems because I only have 2 motorbike batteries.
Have you got another car you can jump off?
dave_424
Speed density is just MAP
Valtra
posted on 11/5/13 at 03:26 PM Reply With Quote
Thanks ...why the f*** doesn't it say that ...
Valtra
posted on 11/5/13 at 03:29 PM Reply With Quote
Hi The battery is a little dull and the engine tight due to new bearings and rings but it is connected to a mains charger .
whipped out the first relay nearest the plug and it shuts up , just going to check online which one that is controlling
cheers
Valtra
posted on 11/5/13 at 03:32 PM Reply With Quote
Ok
now set on speed density
how do the rest of the settings need to be
squirts per cycle 2?
injector staging ?
engine type odd or even fire ?
dave_424
posted on 11/5/13 at 03:42 PM Reply With Quote
2 squirts per cycle
Alternating
most engines are even fire so go with that.
One question, do you have a tune loaded? if you go to basic setup, fuel VE table, do you have a fuel table with a load of numbers?
Dave
Valtra
posted on 11/5/13 at 03:50 PM Reply With Quote
Looks like the fidle relay so perhaps not crucial to getting the car started without Fidle but have I just transposed some wires on setup that is causing the relay to rattle and groan ?
just disconnected the Fidle valve and the relay still buzzes I'll see if I can find it in tuner studio setup
Valtra
posted on 11/5/13 at 03:53 PM Reply With Quote
2 squirts per cycle
Alternating
Dave
Thanks Dave
Yes there are tables there for afr fuel and sparks
dave_424
posted on 11/5/13 at 04:00 PM Reply With Quote
Sorry, but do you have a MAP sensor installed?
If not, then you will have to use Alpha-N (Only just realised that you were using microsquirt)
If I was going to set up your ECU then these are the steps/settings I would use:
Engine constants
- Use the required fuel calculator
- Choose Alpha-N
- 2 squirts per cycle
- Alternating injection staging
- Even fire
More engine constants
- Primary fuel load Alpha-n
- No secondary fuel load
- Multiply MAP
- Don't include AFR target
- Primary ignition load Alpha-n
- No secondary ignition load
Injector characteristics
- 1
- 0.2
- 75
- 25.6
- 66
- Different bank 2 settings off
Don't know ignition settings for EDIS, you probably have an understanding
Ego control off
Cranking settings
- 300RPM
- Flood to clear 80%
- Every event
That should get you started.
What fuel load % numbers do you have? 0-100 or 30ish-100?
dave_424
posted on 11/5/13 at 04:10 PM Reply With Quote
Note that that is only for high impedance injectors
Valtra
posted on 11/5/13 at 04:14 PM Reply With Quote
Engine constants
- Choose Alpha-N
- Even fire
- Multiply MAP
- 1
- 0.2
- 75
- 25.6
- 66
Ego control off
Cranking settings
- 300RPM
- Every event
Hi I've shut up the Fidle relay by changing the idle control algorithm to none perhaps the valve is physically stuck.
Yes there is a map sensor connected up on the TB's it is the standard Suzuki one , I'm prety sure it's wired correctly but not sure if it's setup correctly as I'm sure GM units are the norm settings , but so far been unable to find data
Injectors
tested impedance as 11.8 so high
U tube setup vid recommends
1.0
.2
pwm 100%
time thresh 25.6
66 microsecs
is that ok ?
also you set no afr target is that just to get started ?
fuel load 26-118
dave_424
posted on 11/5/13 at 04:21 PM Reply With Quote
Oh okay then, what does the map sensor read when ignition is turned on, should be very near 100kpa
Those injector numbers are fine.
So if you are getting spark, and getting fuel injected then it should run.
Have you set up the fuel pressure up to the correct pressure?
If so then it should start, how close have you got it to starting so far? one thing I encountered was that it would cough into life from the cranking settings, but when RPM went over the cranking threshold and it wanted to run on the fuel table, it would die. So I selected the group of cells around the idle area and added about 10 to the numbers, after that it started and idled fine.
Valtra
posted on 11/5/13 at 04:26 PM Reply With Quote
Hi just checked fuel pressure when the ignition is first turned on and the pump is operating there is around 4 bar momentarily then it dies as the car does not fire and the pump stops
how am I going to read the map sensor is that on the tuner studio gauges or using my multimeter (what setting if so?)
Valtra
posted on 11/5/13 at 04:31 PM Reply With Quote
No spark !!!!!
where do I start looking . swap Vr sensor terminals ?
<<  1    2    3  >>
