Nickctp
| posted on 6/5/13 at 08:33 PM |
1600 crossflow valve clearance
Evening all,
Can anyone tell me the correct valve clearances for a 1600 Crossflow? I am running a Kent BCF2 cam!
Nick
JAMSTER
| posted on 6/5/13 at 08:45 PM |
BCF2 Camshaft Fast Road VC (mm) 0.36 mm Inlet/ 0.46mm Exhaust
Applications Fast Road
Power Band 2000 - 6500
Cam Lift(mm) 6.62mm Inlet/Exhaust
Valve Lift(mm) 9.69mm Inlet / 9.59mm Exhaust
Duration 290 Deg Inlet/Exhaust
Timing 37/73 73/37
Full Lift Inlet 108 Deg ATDC
LTDC 2.18mm Inlet
Retainer Material Steel
Pulley Material Steel
VSType Single
VSInstalled Height 32.0mm
VSNomSolid Height 19.0mm
VSNominal ID 21.0mm
VSDiameter 28.5mm
BHP Gain Approximately 8bhp increase
LinkRefAddInfo N/A
DavidM
| posted on 6/5/13 at 08:46 PM |
Does this have the info you need?
http://www.kentcams.com/product-details/92/Camshaft/Camshaft/BCF2-Fast-Road/
HTH
Proportion is Everything
Nickctp
| posted on 6/5/13 at 08:52 PM |
Thanks guys
johnemms
| posted on 7/5/13 at 10:14 AM |
My BCF2 SET COLD
inlet 14 thou exhaust 16 thou
All good here
Own chassis & Build - First time pass!!
"7's" aren't really "cars", they are 'experiences"
