Author: Subject: Type 9 Angle drive Speedo
prelude1980
posted on 10/5/13 at 09:55 PM Reply With Quote
Hi all,
quick question, i have an angle drive adapter for my speedo sensor, when i screw the sensor on securely but not overly tight it doesn't work, but if i slacken the sensor it works.
Any ideas on the cause?
thanks
Speed has never killed anyone. Suddenly becoming stationary... that's what
gets you.
https://www.topcashback.co.uk/ref/dodd1980
RichardK
posted on 11/5/13 at 07:50 AM Reply With Quote
Sounds like it bottoming out, is it possible to put a thin washer inside or maybe a circlip to try and lift it slightly?
Rich
Gallery updated 11/01/2011
prelude1980
posted on 11/5/13 at 09:21 AM Reply With Quote
ooh that's a good one i didn't think of, i'll try that this afternoon
gets you.
Daddylonglegs
posted on 11/5/13 at 10:34 AM Reply With Quote
Other option is that there may be something in the recess for the square drive that sits between the gearbox bit and the adaptor?
I am assuming it's the 90deg bit that goes into the gearbox speedo drive? If not, tell me to shove off!
prelude1980
posted on 13/5/13 at 05:09 PM Reply With Quote
A washer between the sender and angle drive worked perfectly
gets you.
