Author: Subject: Spax coilovers
cfc999
posted on 13/5/13 at 01:34 PM Reply With Quote
Spax coilovers
Is there a easy way of testings my old spax coilovers.
Taken one off my car and removed the spring to test. They were new in 1995 and have been sat around in a barn for 15 years. Lots of surface rust so not sure if they are salvageable.
[Edited on 13/5/13 by cfc999]
CNHSS1
posted on 13/5/13 at 01:41 PM Reply With Quote
anyone with a shock dyno can check them out for you. Most larger motorsport teams will have such a beast, find someone local that runs single seaters or GTs and offer them drinking vouchers ;-)
mark chandler
posted on 13/5/13 at 02:13 PM Reply With Quote
If the Chrome stems are rusty they are scrap, if its just cosmetic and the casings you should be okay.
I would just take the springs off,stand them upright and bounce on them, if they all react in the same fashion and do not simply collapse call them good.
Nb do they have adjusting screws down the bottom, when I had some 30years ago the difference between a couple of clicks was huge, not the best ones really.
[Edited on 13/5/13 by mark chandler]
cfc999
posted on 13/5/13 at 03:30 PM Reply With Quote
There is some rust on the chrome and when i push the chrome rod into the coil over housing it slides in (I have to push quite hard) but doesn't push itself back out. To be honest I'm not 100% sure how new ones should feel hence the reason for the post.
They have a screw at the bottom to adjust the ride.
If they are knackered, does anyone have anything lying around that could fit the bill. The springs seem ok apart from needing a lick of paint) and are 9 inch by 3 inch and have 180 written on the bottom ( could this mean they are 180lbs)
owelly
posted on 13/5/13 at 03:46 PM Reply With Quote
The chrome looks ruined. If you work them in and out is there any trace of oil on the chrome sliders?
http://www.ppcmag.co.uk
cfc999
posted on 13/5/13 at 03:54 PM Reply With Quote
Know signs of oil on the chrome sliders but they are very stiff and don't slide in and out very easily.
mark chandler
I do not recall them being gas filled so will not push themselves out.
You have an adjusting screw which will affect the load, only test with them vertical and before you do anything else lightly sand the rust off the chrome with 3000 wet and dry lubricated with something like wd40, although they do look destroyed to me as well.
clanger
posted on 13/5/13 at 06:23 PM Reply With Quote
they are toast...............or soon will be!!!
posted on 13/5/13 at 06:53 PM Reply With Quote
Not just toast but burn't toast.
cfc999
posted on 13/5/13 at 09:02 PM Reply With Quote
Given the chrome a light sand and oil and they seem ok. The screw adjuster clicks when i turn it and firms the action up.
You never know they might do to get me up and running
Chris
Litemoth
posted on 13/5/13 at 10:08 PM Reply With Quote
They'll probably start leaking oil from the adjusters after a trip down't road. They're buggers for it
