J222jra
| posted on 19/5/13 at 10:06 PM |
Xflow clutch to flywheel bolts.
Evening guys,
Today I was preparing to refit my xflow engine, secured the flywheel to the engine and started refitting the clutch when a bolt head sheared off.
Can anyone tell me what tensile strength a clutch to flywheel bolt is supposed to be?
And am I correct saying the bolts are 5/16ths UNC?
James
| posted on 20/5/13 at 06:24 AM |
Not UNC The bolts are 5/16" UNF ----- rotating parts will always have fine threads.
The bolts aren't particularly highly loaded Grade 8.8 or 10.4.
J222jra
| posted on 20/5/13 at 07:01 AM |
Thanks buddy, Burtons advertise UNC?
http://www.burtonpower.com/bolt-clutch-cover-5-16uncx3-4in-x-flow-fp518.html
tomprescott
| posted on 20/5/13 at 08:17 AM |
Pretty sure it will be UNF - I haven't worked on a xflow before but a fairly common metric size (such as pinto's etc) is M10 x 1.0 which
is quite a fine thread...
A bird in the hand....
| posted on 20/5/13 at 07:36 PM |
A lot of the bolts on a X flow are UNC including the clutch cover bolts IIRC . Measure the number of teeth per inch to be sure
