Author: Subject: leaking re build
Valtra
posted on 20/5/13 at 11:56 PM Reply With Quote
leaking re build
Anybody used this and can recommend it?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=251251881056&clk_rvr_id=481820870857
"If it looks like it works and it feels like it works, then it works"
snapper
posted on 21/5/13 at 05:59 AM Reply With Quote
Which bit is leaking?
I eat to survive
I drink to forget
SCAR
posted on 21/5/13 at 06:29 AM Reply With Quote
It fixed the leak on my Citroen's heater matrix over a year ago
Valtra
posted on 21/5/13 at 07:37 AM Reply With Quote
I suspect it could be the newly fitted Head gasket but I can't be sure , the "pig to fit" inlet manifold could also be a source . there is also some seepage around the top hose union casting ( which would have been a thermostat housing on earlier incarnations of the engine) so all in all not good . I realized once the engine was in that I should have fitted the inlet manifold
before putting it in as access was extremely difficult and the sealing compound was disturbed numerous times before I could tighten anything properly . The block was surface planed and the head had been skimmed recently in mileage terms but not during this rebuild .
not what I wanted
SCAR
posted on 21/5/13 at 08:37 AM Reply With Quote
Forget the K seal and get the spanners out.
posted on 21/5/13 at 08:46 AM Reply With Quote
It worked on a pin hole leak in a friend's Land Rover radiator but for a gasket leak I would fix the problem not try to work round it.
Valtra
posted on 21/5/13 at 12:38 PM Reply With Quote
I thought you'd say that ....
demoralizing after such a painstaking re-build and re- engineer (see injection thread) to have got something fundamentally wrong .
Valtra
posted on 4/6/13 at 09:36 PM Reply With Quote
Struck it up again tonight . fingers crossed no leaks this time when it gets warm or I may blub big time
