Author: Subject: Push in Sierra Drive shaft nuts
kajzw
posted on 22/5/13 at 06:22 PM Reply With Quote
Hi Guys,
Just thought I'd throw this out there.....
I really could do with a pair of (LH & RH thread) USED push in type drive shaft / wheel bearing nuts just to tie me over while we complete the mock-up of the rear end, before final assembly and the new nuts / bearings go in, just in case.........
Additionally if you have any of the washers that sit behind said nuts I would be grateful!
Clearly, beer tokens will be offered - just not too many - the car's had most of them
Many thanks,
Keith
tims31
posted on 23/5/13 at 06:32 AM Reply With Quote
Think I may have a a couple, will have a look tonight when I get in.
Build: http://www.martinsfurybuild.co.uk/
ashg
posted on 23/5/13 at 08:46 AM Reply With Quote
if you buy the bearings you get a left and right nut with each bearing so you will essentially end up with 4 nuts.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
kajzw
posted on 23/5/13 at 01:02 PM Reply With Quote
Many thanks guys!
My understanding is that these nuts are essentially single use only, I don't want to drop a bo77ock and then still have to buy another set of new nuts to redo the setup. If I can get the mock up complete with used kit, I'll know it will work first time when all the shiny new bits are used!
tims31
posted on 26/5/13 at 07:21 AM Reply With Quote
Yep I have the left and right nuts and brand new to boot. Came with my new bearings but had new locking nuts fitted to my drive shafts so don't need them for mine.
kajzw
posted on 26/5/13 at 09:02 PM Reply With Quote
tims31,
u2u sent!
Regards,
Keith
