Author: Subject: Garmin 18 5hz GPS receiver
gavin174
posted on 23/5/13 at 06:48 PM Reply With Quote
evening all
I have bought a Garmin 18 5hz GPS receiver for a bit cheaper than ETB can supply one for...
I want to use it with my digidash pro
only problem is it doesnt have a DB-9 connector on it....
can anyone tell me what colour goes to what pin, I have downloaded the manual, but it seems to contradict itself.
in the table is says
1 yellow measurement pulse output
2 red v in
3 black ground
4 white transmit data
5 black ground
6 green recieve data
but in the diagram for a male DB-9 it seems to show
2 red v in
3 black ground
5 black ground
6 green recieve data 1
pin 1 nothing terminated
pin 2 data out - green
pin 3 data in - white
pin 4 nothing terminated
pin 5 ground
can anyone help please
thanks Gavin
[Edited on 23/5/13 by gavin174]
woolly
posted on 23/5/13 at 08:18 PM Reply With Quote
RS232 DB-9 Female Pin 2 - Garmin Brown, DB-9 Pin3 - Garmin White, DB-9 Pin5 - Black (Ground)
Found this for you done it a long time ago for another use seam to remember its about right do a bit more digging around
To confirm.
gavin174
posted on 23/5/13 at 08:25 PM Reply With Quote
thanks for the reply
but even more confussed now.
there is no brown
what do i do with the yellow green and red
MakeEverything
posted on 23/5/13 at 08:41 PM Reply With Quote
Have a look on the sailing forums. People integrate all their stuff all the time, which needs info like this.
Kindest Regards,
Richard.
gavin174
posted on 23/5/13 at 08:46 PM Reply With Quote
thanks Richard
I have spent hours searching, I must be typing the wrong thing in search bar!!
woolly
posted on 23/5/13 at 08:51 PM Reply With Quote
I did it to connect to a logger which only required the data out and ground connected.
As a caution most garmins can handle up to 30 volts in but not all if you are using the car to power it
gavin174
posted on 23/5/13 at 08:56 PM Reply With Quote
ok.. maybe I am trying to over complicate it....
the digidash has a DB9 connector on it that must power the GPS receiver
if anyone has an ETB bought garmin GPS that they can open the DB9 connector and let me know the pin outs..
woolly
posted on 23/5/13 at 09:01 PM Reply With Quote
This makes sense different types of garmin plugs changes colours
Sod it trying to attach a pdf
gavin174
posted on 23/5/13 at 09:05 PM Reply With Quote
i will u2u my email address and you can email it if thats easier
woolly
posted on 23/5/13 at 09:07 PM Reply With Quote
http://priede.bf.lu.lv/ftp/pub/TIS/gps/pcwiring.pdf
gavin174
posted on 11/6/13 at 08:57 PM Reply With Quote
I contacted ETB direct...
and this is the reply I got
"You'll need to send it back because unfortunately it is not just the connector we add, we also re-program them.
For what its worth:-
Pin 2 - Green
Pin 3 - White
Pin5 - Black (Combined)
Pin 9 - Red
(Yellow not used)"
so looks like I will have to send it to ETB
the1theycallthe1
posted on 17/6/13 at 08:23 PM Reply With Quote
Let us know how you get on. I've an ETB & would be interested with the outcome.
Just curious - why are you running a receiver rather than a speed sensor?
gavin174
posted on 17/6/13 at 08:30 PM Reply With Quote
I am using the gps for data logging on track rather than for the speedo
I have dropped the antenna into ETB so will let you know......
