doobrychat
| posted on 30/5/13 at 12:19 PM |
Not an epic fail..
Just got in from IVA at Gillingham..
failed on:-
102db noise test. forgot my baffle..Doh!
Hazard switch has indication between indicators and hazards when on.. Easy 1 wire fix
rear brake flexi hose possible chaffing.. reroute under the rear top wishbone.
handbrake cable possible chaffing on N/S (fix with cable tie)
and thats it..
thoroughly good laugh all morning with the guys..
retest on thursday and mods nearly all done allready...
daveb666
| posted on 30/5/13 at 12:30 PM |
If it wasn't for the noise test would you have been able to do the jobs there and then?
tomprescott
| posted on 30/5/13 at 12:50 PM |
Sounds like a good fail - hope the baffle does the job!
A bird in the hand....
doobrychat
| posted on 30/5/13 at 01:02 PM |
yeh.. considering i was worried about my radiuses of everything..not even checked. my seatbelt mounts.. not even checked my fog and reverse angles....
not even checked.. I knew the emissions were fine but all in all mods are now done... could have got it back today if it wasn't for the red
tape...
ashg
| posted on 30/5/13 at 02:35 PM |
Who did the test? Andy or Neil?
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
Sloan85
| posted on 30/5/13 at 03:45 PM |
What do you mean by "Hazard switch has indication between indicators and hazards when on"
http://mkindygsxr.blogspot.co.uk
doobrychat
| posted on 30/5/13 at 05:42 PM |
Thanks for pointing that out.. when the hazard light is pushed my indicator warning light flashes..its the same for the indicators..there must be an
indication that the hazard lights are on...I chose to be able to see the switch in The dark and the fact my indicator warning light would let me know
its on..
Andy did the test...makes a good coffee...hehe
doobrychat
| posted on 6/6/13 at 03:09 PM |
From minor fails to a pass...
even with baffle in it was 100.3db... got tshirt shredded it and wrapped baffle in that then 98.3db.. got my ticket and i was off on the longest route
home i could think of..
your all right about my top speed with a 3.92 diff its flat out at 110.... 3.62 going soon...
thanks to all those that help me get this far..
matt_gsxr
| posted on 6/6/13 at 03:19 PM |
How did you sort the emissions in the end? I remember you had some problems but can't remember whether I saw the final conclusion.
doobrychat
| posted on 6/6/13 at 03:24 PM |
fitted the pc3 usb off my bike to it and mapped it too: +8 at 1500 rpm and -30 at 2750rpm..
PC3 is coming off now and going back on my bike... I'm off to put my indicators back to where they should be and ditch all those silly bits of
trim....
adithorp
| posted on 6/6/13 at 03:32 PM |
Nice one!
Just DVLA hoops to jump through now.
http://jpsc.org.uk/forum/
daveb666
| posted on 6/6/13 at 03:39 PM |
I'm assuming the car has no numberplate on when you did your long drive home?
doobrychat
| posted on 6/6/13 at 06:16 PM |
of course...hehe
