Author: Subject: 1300 xflow help
se7en
posted on 4/6/13 at 08:50 PM Reply With Quote
1300 xflow help
I have been offered a Ford 1.3 xflow as in the attached pictures. It is from a Escort Mk5? and the owner tells me that it has less than 20,000 miles on it. It is definitely a 1.3 as that is the marking on the side of the block.
The question that I have about it is that it looks like the Endura or the HCS engine but I do not know what the tubes coming out of each cylinder are and what is the unit on the rear of the engine that they run into.
Can someone please identify this engine and would it be be any good to use in my kit-car?
Thank you
7
myke pocock
posted on 4/6/13 at 08:59 PM Reply With Quote
Dont know what the tubes are but if its a Mk5 I think it doesnt have the castings on the block for the engine mountings as it would have been transverse FWD. Can someone confirm if I am right? I was offered a Fiesta engine once but that didnt have the castings.
busakid
posted on 4/6/13 at 09:07 PM Reply With Quote
engine
not a x-flow that, its a hcs engine
mark chandler
posted on 4/6/13 at 09:23 PM Reply With Quote
Tubes are for letting air into the exhaust to improve emissions, helps the CAT heat up.
remove the whole lot and block the holes, if they are funny threads just saw off the tube and stick a blob of weld on top then bolt back in.
Not Anumber
posted on 4/6/13 at 09:31 PM Reply With Quote
As there are no positions on the side of the block for engine mounts you would need to fabricate something to do the job with brackets to bolt positions elsewhere on the engine. It could be done. An original Kent crossflow would be easier but it would be a good challenge to fit this in a rwd configuration. What are the ignition arrangements with this, does it have a distributor or Edis and coil pack ?
se7en
posted on 4/6/13 at 11:12 PM Reply With Quote
Thank you all for your replies.
Engine mounts did not occur to me when I was looking at the engine. These engines are mounted in the car using a mount at the front (left side), high up on the engine. It would make an interesting project but one that I don't really take on.
The ignition uses the EDIS and coil pack mounted on the block below the inlet manifold.
Again, thank you all for your contributions.
7
