Author: Subject: Sidelight options
jon200
posted on 10/6/13 at 07:21 PM Reply With Quote
Sidelight options
I have fitted some projector headlights and hadn't thought about side lights! I can't fit anything inside the light so that leaves me with a few options
1, a small light next to the headlight(any suggestions?)
2, change the indicator lights to clear ones and put a light in them?
3, put some side repeaters on the front cycle wings?
What have you done or tried? Any other suggestions.
Jon
adithorp
posted on 11/6/13 at 07:37 AM Reply With Quote
I'd probably go with option 1. Put some small sidelights on the headlight mounting bracket; You should be able to find some LED lights that'd look neat. Just have a look through SVC and CBS catalogs or have a mooch around Halfords or local motor factors.
http://jpsc.org.uk/forum/
blakep82
posted on 11/6/13 at 08:38 AM Reply With Quote
i've got these to use as indicators and sidelights on the front.
ok, as indicators they are very small... but they are very bright, and in the manual there's no mention of minimum sizes. get one, try it and see what you think
2 Button 12v White LED Ligts Boot/ICE/BassBox/Install | eBay
________________________
steve m
posted on 11/6/13 at 08:52 AM Reply With Quote
I have the same ones as Blake, and they are VERY bright, so i use them as day running lights,
blakep82
posted on 11/6/13 at 08:56 AM Reply With Quote
thats what i was thinking, could either wire them in as sidelights, on a switch, or wire them into the ignition as daytime running lights, which is probably what i'll do
i using them as front indicators, side repeaters, and 1 white one as a reversing light
jon200
posted on 11/6/13 at 07:56 PM Reply With Quote
Thanks Blake just ordered some. Do sidelights need to be switchable or can they be on with ignition on and still pass an MOT?
blakep82
posted on 11/6/13 at 08:48 PM Reply With Quote
A very good question...
Not 100% sure tbh. I guess if they're switched, as sidelights, then the tail lights need to come on
If they come on with ignition, as DRL, then only they need to come on, without tail lights?
jon200
posted on 11/6/13 at 11:53 PM Reply With Quote
I will just wire them into the sidelight circuit anyway. Easier than messing about with more wiring!
