Author: Subject: Mx5 wiring and ecu
eagle
posted on 23/6/13 at 07:09 PM Reply With Quote
Mx5 wiring and ecu
Hi
A mate of mine is starting to build a mx5 based zero
Does anybody know if we can use the original loom and ecu
The car is a 98 mk2 1.8
Thanks any pointers would be very helpful
Smoking Frog
posted on 24/6/13 at 05:16 PM Reply With Quote
Yes you can, although there will be a fair bit of the loom not used which makes installing complicated. Careful labeling when removing the loom will help. When I did mine I found it easier to make my own loom using mostly trailer cable and just use part of the original loom for the engine, ECU harness.
Slimy38
posted on 24/6/13 at 06:10 PM Reply With Quote
Apologies for the thread hijack, but could I ask whether you did anything special for the immobiliser? Or was that retained along with the ECU?
Smoking Frog
posted on 24/6/13 at 06:21 PM Reply With Quote
Sorry can't answer that although my engine loom is from a MX5 it's a 1991 1.6 so no immobiliser.
rdodger
posted on 24/6/13 at 07:48 PM Reply With Quote
I used a 99 mk2 as my donor. Loom immobiliser and all. I also used the steering column with stalks.
There is an amazing amount lot to strip out for such a small car.
I found this invaluable
http://www.madracki.com/miata/wiring.html
The only difference I found was with the alternator wiring as on the MK2 it's controlled by the ECU.
