Talon Motorsport
| posted on 27/6/13 at 02:24 PM |
v6 cologne exhaust CAD
I know it's a bit of a long shot but has any body got a CAD drawing of the exhaust flanges for a 2.8 - 2.9 ford V6 Cologne engine?
CNHSS1
| posted on 27/6/13 at 02:44 PM |
might be worth asking over on pistonheads in the TVR 'S' forum as they used both the 2.8 and 2.9 colognes. I *think* one or tother had
more than one port shape (oval and round??) but may be getting mixed up with the Essex.
The 2.9 24v is a differing port shape than the 12v too I think, but the Tiv guys wil know as its a popular swap into an S series
Talon Motorsport
| posted on 27/6/13 at 02:49 PM |
Ah thanks will have a try over there, don't really want to take a paper rubbing to the laser cutters I'll get laughed out of the office.
scimjim
| posted on 27/6/13 at 05:12 PM |
don't have either I'm afraid - but 2.8 & 2.9 Colognes are totally different engines. The 2.8 has siamesed exhaust ports
(manifolds have 2 pipes each side) but the 2.9 has "proper ports (3 each side). AFAIK, the only interchangeable parts are the rocker box covers
- the cam even rotates in the opposite direction (chain versus wheels)!
turbodisplay
| posted on 27/6/13 at 06:27 PM |
Buy an exhaust gasket from ford and take measurements.
Done that a few times
Darren
CNHSS1
| posted on 27/6/13 at 09:00 PM |
Darren
not sure about 2.8, but my 2.9 in my Tiv is 3 separate gaskets per side so you don't get the relationship between each
turbodisplay
| posted on 27/6/13 at 09:25 PM |
I do think they are seperate, the 2.9 cosworth is. I welded the flanges using the head to hold them in place.
Alternative is use an exhaust manifold.
Darren
scimjim
| posted on 27/6/13 at 09:31 PM |
2.3, 2.6, 2.8 Cologne, 2.4, 2.9 US Cologne (12 & 24v) are all individual gaskets - as are the V4 & V6 Essex. The 24v Cosworth 2.9i is the one
with "square" ports.
dhutch
| posted on 28/6/13 at 03:29 AM |
Sounds like some work is required to know what you want.
Bit you have the dims (hole diameters, distance between centers, etc) its a 30 second job to turn that into an engineering drawing (pen an ruler
works) or to model it on cad and produce a dxf pattern for the laser guys.
Daniel
