| posted on 29/6/13 at 08:57 PM |
Di Resta disqualified --- driver under weight !
Paul Di Resta has been disqualified from British GP qualifying combination of car and driver was 2kg under on the scales, deducting allowed error
margin that means 1.5kg over.
Paul himself weighed in at 1kg under his registered weight. When weighed latter Pau'ls weight was back up to his required weight.
The bummer is the team cannot ballast up the car because that counts as changing the setup under Parc Ferme rules.
[Edited on 29/6/13 by britishtrident]
david_hornet27
| posted on 29/6/13 at 09:17 PM |
He can change setup if he starts from the pits I guess...
'If everything seems under control you're just not going fast enough' - Mario Andretti
theconrodkid
| posted on 29/6/13 at 09:23 PM |
have a nice healthy fry up,that should add a couple of pounds
who cares who wins
pass the pork pies
jossey
| posted on 29/6/13 at 09:30 PM |
That's mad.
David Johnson
Mr Whippy
| posted on 29/6/13 at 10:25 PM |
Must have been poor toilet break timing...
| posted on 30/6/13 at 07:52 AM |
Obviously Force India were being a wee bit too marginal with their car weights but something is wrong for the FIA scales to be out by 0.5kg
considering the accuracy of modern electronic scales.
As for the driver weight ????????????????????????
Aaron_n_Sim
| posted on 30/6/13 at 10:23 AM |
He's starting from the back of the grid.
Work to Live don't Live to Work
