Author: Subject: R1 (2003) lost oil pressure
spdpug98
posted on 3/8/13 at 08:42 PM Reply With Quote
I was out today for a little run, unfortunately towards the end I lost all oil pressure quickly followed by the water temperature rising to 120deg+!!!!
I've got the engine out the car and spoken to a neighbour who thinks it could be the oil pump, as it is the pump for the oil & water
Has anyone had similar issues and able to offer any advice
My Blog: http://spdpug98.wordpress.com/
adithorp
posted on 4/8/13 at 07:46 AM Reply With Quote
Could be the drive to the pumps. It's a chain drive to the shaft that drives both water and oil pumps.
How long did it run from loss of oil pressure to switching off? You don't get long before the bearings get damaged.
http://jpsc.org.uk/forum/
spdpug98
posted on 4/8/13 at 07:54 AM Reply With Quote
I've checked the chain, it's still connected / not snapped, I'm working on the basis that it'll need new bearings as ran for about 800m without pressure
spdpug98
posted on 5/8/13 at 06:52 PM Reply With Quote
Bottom end stripped down, the culprit was a seized oil / water pump - doesn't look to bad inside so think I've got away with it - fingers crossed
adithorp
posted on 5/8/13 at 07:09 PM Reply With Quote
If you've got decent oil in it and it wasn't under a lot of load then the bearings could well be OK. Did you find any cause for the siezed pump?
spdpug98
posted on 5/8/13 at 07:20 PM Reply With Quote
If you've got decent oil in it and it wasn't under a lot of load then the bearings could well be OK. Did you find any cause for the seized pump?
Was using a good oil, so no worries there - I've not stripped the pump yet, here is a pic of the bearing:
[IMG]http://i71.photobucket.com/albums/i140/spdpug98/CapampBearing.jpg[/IMG ]
