Author: Subject: Loom Connectors
daveb666
posted on 6/8/13 at 06:53 AM Reply With Quote
Loom Connectors
Doe anyone know of any websites that sell wiring loom connectors please?
Namely injectors, coil, crank sensor and coolant temp. There are no local scrappers to me where I can go and scavenge myself so I'm probably going to have to buy new.
gavin174
posted on 6/8/13 at 06:59 AM Reply With Quote
not used these myself,
but looks like a good supply..
http://www.durite-shop.co.uk/
[Edited on 6/8/13 by gavin174]
r1_pete
Vehicle Wiring Products have always come good for me Link
I have a load of junior timer sockets, used but with tails and rubber boots, if they are are any good to you let me know how many you need.
daveb666
posted on 6/8/13 at 07:17 AM Reply With Quote
Thanks both.
pete; if I get a few pics of the ones I need can you check to see if yours match please?
I'll need:
4 x injectors
1 x crank sensor
1 x coolant temp sensor
The SBD loom I've acquired was used on a CVH so none of the above connectors fit the sensors/injectors on my zetec; doh.
rdodger
posted on 6/8/13 at 08:08 AM Reply With Quote
http://www.polevolt.co.uk/
matt_gsxr
posted on 6/8/13 at 09:05 AM Reply With Quote
Another one I came across the other day
http://www.efi-parts.co.uk
Not used them myself yet.
r1_pete
posted on 6/8/13 at 09:24 AM Reply With Quote
This is the type I have, they fit the zetec crank sensor etc.
If they're any good, cover the postage and I'll send you enough plus some spares.....
plug
plug
big_wasa
posted on 6/8/13 at 11:54 AM Reply With Quote
Yep the injectors are mini timer housings as above. Some have a semi circle cut out of the back like the pic above to clear the back of the injector. Some dont and wont fit injectors but they will fit stuff like the crank sensor ect.
The only place I know of that does the coil pack conector is trigger wheels but cheap it aint. The coolant sensor is a differant story. The one in your stat housing is likley to be a denso style plug. Is this sensor compatable with your new MBE ecu ? some ecu's can be calerbrated to the sensors range some use a pecific sensor. Often a Gm part.
I take it you are leaving the eec-v loom intact ?
I may have a spare coil and coolant plug but I will have to check as I gave most of the plugs away after finishing the last one.
cheers
jimmyd
posted on 6/8/13 at 11:56 AM Reply With Quote
R1_pete,
I could use a couple of those for a few beer tokens, any more available?
J
r1_pete
posted on 6/8/13 at 12:19 PM Reply With Quote
They have the semi circle cutout, they came from Jag Injector looms I scrapped, its just a pity they don't fit Subaru / Denso Injectors.
I've a bag full, probably 50 or so, I left about 150mm tails, but they could be joined inside the rubber boot and the join be invisible.....
Jimmyd you have a PM.
[Edited on 6/8/13 by r1_pete]
big_wasa
posted on 6/8/13 at 03:38 PM Reply With Quote
50 wow and I thought I was a connector whore
r1_pete
posted on 6/8/13 at 05:33 PM Reply With Quote
Yes I wanted an XJ6 EFI manifold to mod for the E Type, and ended up with 5 - its a long story.....
Plugman
posted on 17/8/13 at 07:44 AM Reply With Quote
We have been selling connectors for a few years and hold most of what you need:
brandshatchperformance.com
Always happy to help out other builders, so if you have any questions or queries feel free to ask
