Author: Subject: What build diary/pics are needed?
Rob55
posted on 20/8/13 at 07:45 AM Reply With Quote
Does the IVA man expect a build diary and detailed photos and if so what am I expected to put in it? I couldn't see anything in the manual about this but have heard people mention it in passing. Is it definitely required? Any examples I could follow?
loggyboy
posted on 20/8/13 at 07:51 AM Reply With Quote
I dont think its a specfic requirement, but its in case theres any places he cannot see (ie a fully enclosed riveted tunnel) just to prove you have secured the pipes, loom etc adequately.
I think its more for the DVLA that the photos are useful, to prove the stripped parts of your donor were removed from the donor, and that you made the car (to declare as an amatuer build).
For example an imported car would not have a build diary, but would still require IVA to be registered.
[Edited on 20-8-13 by loggyboy]
Mistral Motorsport
Rob55
posted on 20/8/13 at 07:53 AM Reply With Quote
Ah - so is it actually for registration the diary is needed? Do you know where the guidance is to show me what I'm supposed to be keeping?
I am going for a new reg, so want to keep myself right!
daveb666
posted on 20/8/13 at 07:57 AM Reply With Quote
I took a disc of photos to my IVA test, they were never asked for.
I included a disc full of build photos for the DVLA application, the CD was returned un-opened as I had sealed the case on purpose.
loggyboy
posted on 20/8/13 at 08:14 AM Reply With Quote
I wouldnt worry too much about photos, take some general build photos, and as I say anywhere that is enclose, just in case.
For DVLA registration the most important things you need are reciepts, specfically of the main items, chassis, engine, suspension, etc etc. and if you using the one 'reconditioned to as new' part you, need a reciept for that too.
Mistral Motorsport
40inches
posted on 20/8/13 at 11:11 AM Reply With Quote
Same here, the disk was still sealed when it was sent back from VOSA/IVA. I think it's a case that if you don't send them they will need to see them
Acc8braman
posted on 20/8/13 at 11:23 AM Reply With Quote
In terms of Pics, do you really need to be in the pictures themselves?
I bought my kit part built so only have a receipt for that and someone else finished it off for me!?!?
Will I have problems with the pics I have with me not in them?
rb968
posted on 20/8/13 at 12:50 PM Reply With Quote
I also sent photos off on CD and printed and no idea if they looked at them
However I took the printed ones with me to the IVA test itself where they came in handy to show the tester the mounting points for the seatbelts in the tunnel and how they were welded etc. Otherwise might have meant pulling more panels off.
So if you have photos of any inaccessible welds or mounts then might not be a bad idea.
Rich
40inches
posted on 20/8/13 at 06:08 PM Reply With Quote
I wasn't on any of them, but it was obvious that it was in a domestic garage. However, as I said, they didn't even look at them, probably too much hassle to view them on a PC.
