Author: Subject: Which harness
Rob55
posted on 20/8/13 at 08:20 AM Reply With Quote
Which harness
Would you guys recommend a 4/5/6 point harness for racing and are they all a standard size?
minitici
posted on 20/8/13 at 08:34 AM Reply With Quote
If you are going 'circuit racing' your belts will need to be FIA homologated harnesses (and in date).
For speed events (hillclimb & sprint) the belts do not need to be FIA.
If you have a reclined driving position you would need crutch straps (5 or 6 point) harnesses.
If your car would run in Sports Libre category in speed events then 5 or 6 point are mandatory.
If you intend using a Hans device you should consider belts specifically designed for use with the Hans device.
Rob55
posted on 20/8/13 at 08:48 AM Reply With Quote
No need for HANS but I will need FIA approved. I presume 5 point is a recipe for pain the in the nether regions?
loggyboy
posted on 20/8/13 at 08:50 AM Reply With Quote
Better than the pain of submaring the seatbelt and falling out the car.
Mistral Motorsport
Rob55
posted on 20/8/13 at 08:53 AM Reply With Quote
So 6 point it is then..
