<<  1    2  >>
Author: Subject: Lighting gas with sparkplug
tegwin
posted on 24/8/13 at 10:59 AM Reply With Quote
I am trying to build the igntiion system for my little jet engine. Using a 555 timer as an astable to excited an automotive coil at about 300Hz...
I can get the plug to buzz with a purple arc but it won't fire off the gas. The piezo ignitor in my blowtorch does a much better job with a single white arc. Any thoughts on how I can improve the spark and get the gas to light off?
www.verticalhorizonsmedia.tv
dave_424
posted on 24/8/13 at 11:07 AM Reply With Quote
reduce the frequency to give the coil more time to charge?
Dave
JC
posted on 24/8/13 at 12:00 PM Reply With Quote
Prime engine with damp start? Spark will light this which will light gas, jet should then be self sustaining?
PhillipM
posted on 24/8/13 at 12:09 PM Reply With Quote
What coil charge time are you getting there?
3ms isn't a whole lot of time to charge, trigger, discharge and start again unless you have a good coil and driver.
What's the signal duration you're getting out of your circuit for a single pulse?
[Edited on 24/8/13 by PhillipM]
tegwin
posted on 24/8/13 at 12:10 PM Reply With Quote
The issue is lack of energy in the spark to get it to light off the gas in the first place....
I wonder if my coil is knackered...
Looking at it I think I would be better off with a CDI and coil rather than the traditional coil I am using, would negate the back EMF issue I am having with the switching transitor..
Anyone have a CDI and coilpack kicking about? I only need a single plug though.
tegwin
posted on 24/8/13 at 12:26 PM Reply With Quote
Hi.
(from theory)
Total period of 0.00311849 seconds
High time of 0.003049199 seconds
I have the 555 astable switching a cylindrical oil filled automotive coil via a large transistor.
There are videos on youtube of similar setups kicking out quite some impressive sparks at varying frequency ranges... Suspect something in my setup is not right. Possibly the coil.... The transistor gets hot too as well which is not ideal
skov
posted on 24/8/13 at 01:34 PM Reply With Quote
Is the transistor tuning fully on? If not, that could explain why it's getting hot and you have a poor spark.
tegwin
posted on 24/8/13 at 01:36 PM Reply With Quote
Good point. What's the best way of checking that it is? Measure the voltage across it?
skov
posted on 24/8/13 at 01:46 PM Reply With Quote
Best way is to stick a scope on there. A volt meter won't tell you much at 300Hz.
Can you post up a diagram of the circuit?
tegwin
posted on 24/8/13 at 01:53 PM Reply With Quote
Sadly I don't have a scope. Only a multimeter with a frequency counter on it.
This is the circuit I am using.
The actual astable part seems to work ok as I can measure the expected frequency at pin 3.
If I run with the 1K resistor between pin 3 and the transistor then it doesn't work...
skov
posted on 24/8/13 at 02:51 PM Reply With Quote
I like the retro transistor
Not so keen on the circuit though... It might work on a good day, but you really want another gain stage between the 555 and transistor, or a perhaps a different transistor with a higher gain (a darlington would be better).
Presumably it must still work (to some extent) with the 1k in there as it does spark a bit?
Without redesigning it, I think I'd try lowering the value of the 1k resistor to around 500R to see if that makes any difference.
tegwin
posted on 24/8/13 at 02:53 PM Reply With Quote
If I have the 1k in before the tranny it doesn't spark atall. It's removed at the moment. Would it be worth adding a smaller transistor before the big one do you think? If you can see a better way of doing it I would be so grateful for a sketch
skov
posted on 24/8/13 at 03:05 PM Reply With Quote
So have you currently got the output of the 555 connected directly to the base of the transistor?
You want some resistance in there or you'll risk damaging the 555 and/or the transistor.
[Edited on 24/8/13 by skov]
paulf
posted on 24/8/13 at 03:40 PM Reply With Quote
Have you tried running it at a lower frequency? it does not need to spark at that frequency to ignite so maybe 75 or 100 hz may give time for a stronger spark output.If the coil drive is the problem then maybe it would be possible to use an ignition amp from a contactless distributor to drive the coil and feed it the signal from the 555.
Paul
gremlin1234
posted on 24/8/13 at 03:56 PM Reply With Quote
is D2 in the right place? I would have expected it across the coil.
http://en.wikipedia.org/wiki/Flyback_diode
designer
posted on 24/8/13 at 04:10 PM Reply With Quote
Why not a glow plug?
posted on 24/8/13 at 05:31 PM Reply With Quote
Use a piezo from a Calor burner, they light my blow heater, simple to fit and only cost a few quid with no complicated circuits. Ignito r and lead for under a tenner.
posted on 24/8/13 at 07:57 PM Reply With Quote
There are several things wrong here:
1) A 2N3055 has very low current gain at high collector current. If you want to get a primary current of 5 Amps or so you will need to be putting at least 0.5 Amps into the base to switch it on, and preferably a little more than that to be sure of driving it into saturation. Obviously a 555 timer can not deliver that level of current (especially not with a 1k resistor in series!), so you will need a driver stage before the 2N3055.
2) The maximum permissible voltage across the collector and emitter of the 2N3055 is about 60 volts, making it inherently unsuitable for driving an ignition coil. Above this voltage the transistor junction will start to break down. Since the secondary voltage is directly related to the primary, limiting the primary voltage to such a low level means a low secondary voltage as well. Typically you want to allow the primary voltage to reach 200-300v. With a bipolar transistor you must provide suitable protection to prevent the voltage exceeding this level, which you don't have (D2 is doing nothing really, since the reverse breakdown of a 1N4007 is around 1000v).
3) The duty cycle of the 555 is way too high, you are allowing about 3ms for the coil to charge which is not unreasonable, but you are only giving the coil 70 microseconds to discharge which is too short. About 1ms would be correct for an inductive system like this.
They way to fix most of this this in one fell swoop is to ditch the prehistoric 2N3055 and replace it with a suitable IGBT, rated for ignition systems (e.g. BIP373). These have simple voltage drives to the gate and usually provide inbuilt clamp for voltage protection.
You could also use a simple ignition amplifier module, such as those used in the 80's on cars that came with electronic ignition from the manufacturer.
[Edited on 24/8/13 by MikeRJ]
tegwin
posted on 28/8/13 at 09:28 AM Reply With Quote
Thanks for your thoughts all.
This looks like an interesting product http://www.maplin.co.uk/ignition-amplifier-kit-3162
If I used that I should be able to fire it off with a simple transistor feed from the 555!?
BaileyPerformance
posted on 28/8/13 at 09:46 AM Reply With Quote
It's the diode across the 2055 that's clamping the fly back and preventing the coil from releasing the charge to the secondary.
Replace the diode with a 1.0mf 250v poly cap.
A 2n3055 has quite a low C E breakdown voltage so no sure how long if will last, plus you need at least 150ma at the base to fully switch it on assuming the coil is pulling 10amps. Another transistor configured in Darlington pair would help.
A just your 555 to 100hz with mark space of 20% ish to avoid overcharging the coil and frying the 2055.
Not Anumber
posted on 28/8/13 at 11:23 AM Reply With Quote
This sounds like the jet engine would have similar ignition requirements to an exhaust flamer kit such as this one on the bay:
http://www.ebay.co.uk/itm/FLAMER-KIT-FLAME-KIT-EXHAUST-FLAMER-FULL-KIT-/321050177765?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4ac014f0e5
Mr Whippy
posted on 28/8/13 at 12:09 PM Reply With Quote
And why is there no picture of this jet engine????
Lets see it, what you going to do with it? I'd like a jet engine they sound so cool
scudderfish
posted on 28/8/13 at 01:44 PM Reply With Quote
My BOE calcs say a 3ms spark is equivalent to a 4 cyl engine doing 10,000 rpm. If you're just trying to light a jet engine, do you need to be banging away that fast? Is the coil charging enough in that time?
Mr Whippy
posted on 28/8/13 at 02:47 PM Reply With Quote
Chances are the mixture is wrong and the flash point to high for a simple spark to ignite. A car gets away with it because the compression stroke heats the air mix up.
You only need a spark every half second or so but it's going to have to be very hot, even then it might need a blast of fresh air to fire up
I'm sure you can hear the spark ticking away on youtube vids of jets starting up, there not very rapid at all
[Edited on 28/8/13 by Mr Whippy]
Dualist
posted on 28/8/13 at 03:31 PM Reply With Quote
I had problems with the above circuit years ago and as I know nowt about electronics me and my mate just used a vacuum cleaner on blow and blowtorch on the outlet, was a bit of a nack trying to get the flame to go back inside past the blades but it worked
[youtube]http://youtu.be/xXKjUWMiwnc[/youtube]
[Edited on 28/8/13 by Dualist]
Rotary build coming soon...
Originally posted by RichardK
I recently discovered that pigs can p i s s sideways when being transported
<<  1    2  >>
