Author: Subject: Another tapping issue with a Pinto
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 25/8/13 at 10:36 PM Reply With Quote
I have had this problem for quite a while, there is a noticeable tapping noise from the engine bay when the engine is under load.
I would say it sounds like regular knocking but I'm really not sure what would cause it but ut sounds like it is rom the engine itself.
It happens when hot or cold and at all revs when the engine is under load. When off the accelerator or idling there is no noise at all.
The car has a Kent Fast Road Cam and bike carbs.
Any ideas as to what I can check to get this sorted, I am going to Nurburg in November so trying to ensure it is top notch before I leave!
mookaloid
posted on 25/8/13 at 11:34 PM Reply With Quote
could be bearings or piston slap if internal to engine.
If not internal to engine possibly something hitting the chassis or fouling somewhere?
I'm only in Harrogate if you would like a second opinion - not an expert but I've had a few engines with faults in the past.
Mark
snapper
posted on 26/8/13 at 05:43 AM Reply With Quote
Could it be ignition knock
Check spark timing
I eat to survive
I drink to forget
madteg
posted on 26/8/13 at 08:44 AM Reply With Quote
How long has it been there. It could be the valve springs boxing it the cam has been fitted onto standard springs.
jacko
posted on 26/8/13 at 01:11 PM Reply With Quote
My pinto use to tap on a chassis bar it was the alternator pulley i fitted this to stop it
engine mounting
engine mounting
Jacko
teegray19
posted on 26/8/13 at 05:34 PM Reply With Quote
I had a tapping noise coming from a old crossflow engine, turned out to be a mixture of blown exhaust gasket and exhaust sitting in the chassis.
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
posted on 26/8/13 at 08:38 PM Reply With Quote
hmm, some interesting things to look at here. I will investigate more for something like alternator belt slapping. Mookaloid, I might need to take you up on your offer!
It occurs even at the slightest of touches on the accelerator in any gear.
