Author: Subject: What oil
jacko
posted on 26/8/13 at 11:01 AM Reply With Quote
What oil
For a Sierra lsd
What type do people recommend me to use thank's
Jacko
imp paul
posted on 26/8/13 at 11:13 AM Reply With Quote
you need sae 90w one litre thats it hope that helps
jacko
posted on 26/8/13 at 11:40 AM Reply With Quote
Yes thank you any recommendations on make will GL5 be ok ?
Jacko
mcerd1
posted on 26/8/13 at 12:07 PM Reply With Quote
it needs to be GL5 for the diff
but any decent brand will be fine - I don't think they are that fussy...
got an old bottle of castrol EP90 for mine (looks like they make a slightly different range these days)
opie oils recommend this stuff:
http://www.opieoils.co.uk/p-972-fuchs-titan-gear-hyp-90-hypoid-gear-oil-gl5-80w-90.aspx
[Edited on 26/8/2013 by mcerd1]
imp paul
posted on 26/8/13 at 12:10 PM Reply With Quote
this is what you want pal http://shop.grahamgoode.com/differential-oil-cosworth-2wd--4x4--1-litre-millers-crx-75w90nt-fully-synthetic-59283-p.asp
posted on 26/8/13 at 05:30 PM Reply With Quote
The final drive in Sierra viscous diff uses an ordinary GL5 Hypoid gear oil.
The original grade was EP90 GL5 Hypoid but that is commonly supplanted these days by EP75/90 GL5 Hypoid or EP80/90 GL5 Hypoid.
The GL5 part of the grade designation is the important bit.
Any reputable manufacturers( Castrol, Comma, Carlube even Halfords) gear oil that meets those requirements will do the job.
