<<  1    2  >>
Author: Subject: Striker front lower wishbone failure
sky
posted on 26/8/13 at 03:23 PM Reply With Quote
Very dangerous, fortunately it happens on a straight line at low speed.
From where comes the lower ball joint and the lower wishbone's bushes of a Sierra based Striker?
shaun fulcrum
posted on 26/8/13 at 03:43 PM Reply With Quote
I got one from raw recently, think it was about £18 delivered. Didn't know what it was so just went to them.
Hope the damage is minimal?
sky
posted on 26/8/13 at 03:48 PM Reply With Quote
Yes, only the lower wishbone but if it happened on the twisty roads I could have gone like a rocket on the mountain or down into the canyon.
shaun fulcrum
posted on 26/8/13 at 04:02 PM Reply With Quote
Did it break on the weld? Any undue stress (pothole) or just completely random? Got me paranoid now
sky
posted on 26/8/13 at 04:05 PM Reply With Quote
Seems on the weld but I've to check better.
Completely random, just apparently normal corrosion.
clanger
posted on 26/8/13 at 04:07 PM Reply With Quote
glad you're ok. hope it wasn't the same person who welded the wingstays.............Mr Pigeon Chit...
shaun fulcrum
posted on 26/8/13 at 04:22 PM Reply With Quote
Deffinately checking mine thoroughly before the next outing!
Glad all ok otherwise.
designer
posted on 26/8/13 at 04:33 PM Reply With Quote
What diameter is the tubing?
sky
posted on 26/8/13 at 04:39 PM Reply With Quote
If I remember correctly 19 mm of diameter, 1 mm of thickness.
I would like the next wishbone to be 25 mm of diameter with 1.6 mm of thickness.
jeffw
posted on 26/8/13 at 04:40 PM Reply With Quote
Happened on my Phoenix but then they where 19 years old when they let go. Raw have them I'm sure.
sky
posted on 26/8/13 at 04:43 PM Reply With Quote
I sent a mail to RAW
loggyboy
posted on 26/8/13 at 04:44 PM Reply With Quote
They're a maxi joint IIRC
Mistral Motorsport
theprisioner
posted on 26/8/13 at 05:30 PM Reply With Quote
Is that a part originally manufactured by Sylva Autokits or RAW engineering?
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
sky
posted on 26/8/13 at 05:33 PM Reply With Quote
Don't really know.
austin man
posted on 26/8/13 at 06:01 PM Reply With Quote
I was never happy with using the small round bar I had my Locost ones remade in oval tube as the originale started to bend
pewe
posted on 26/8/13 at 06:14 PM Reply With Quote
That's why on the F27 I went for 25mm diam and 3mm wall thickness tubing.
Suspect it only adds marginally to the car's overall weight but gives a better sense of security.
Cheers, Pewe10
Werner Van Loock
Make sure you also replace the other wishbone, probably on it's way to failure too.
How much castor has your front? If it's too much it might give stress on the bottom balljoint under load and thus stress on the wishbone.
http://www.clubstylus.be
sky
posted on 26/8/13 at 06:22 PM Reply With Quote
Yes, I'll replace also the other.
A lot of castor, more than 10 degrees.
strikerguy
posted on 26/8/13 at 06:23 PM Reply With Quote
On a trackday i have seen lower wishbones bend back after heavy braking. Reason for some to box up the tubes, so much like the upper wishbone.
Carbonman
posted on 26/8/13 at 07:30 PM Reply With Quote
Isn't that the same corner you have been working on recently, as in your"which upright" post?
Carbon Copies Ltd
posted on 26/8/13 at 07:31 PM Reply With Quote
Definately not a Maxi joint from the pictures. There is a large hex visible on the ball joint body so it seems they may be screwed into the wishbone/upright adapter which would make the Metro balljoint a strong possibility.
Talon Motorsport
posted on 26/8/13 at 08:05 PM Reply With Quote
Please tell me there not people out there making lower wishbones for road use from 1mm tube?
sky
posted on 26/8/13 at 08:08 PM Reply With Quote
It's possible that I don't remember correctly the thickness...I will check!
sky
posted on 26/8/13 at 08:11 PM Reply With Quote
Yes, but over a year ago, working on both corners and not a problem at all with a few miles on the road and a couple of trackdays.
I think the main problem was the rust inside the tube.
Bare
posted on 26/8/13 at 09:06 PM Reply With Quote
On looking at your broken tube photo.. there is Rust ! visible on the broken end.
Unless you parked it in the rain for days before taking the photo, that thing was Pre-broken, for ...some time... previous.
Frankly it's a Bodge design .. But inept welding played it's part ?
[Edited on 26/8/13 by Bare]
<<  1    2  >>
