New Topic New Reply
Author: Subject: MK Indy windscreen
Brackers
posted on 26/8/13 at 07:12 PM Reply With Quote
MK Indy windscreen
Hi all anyone know of an indy screen for sale anywhere? MK say they having prob with supplier. I am considering GBS, anyone know if they fit well with Indy? Cheers
YQUSTA
posted on 26/8/13 at 07:28 PM Reply With Quote
GBS used to supply MK, I bought mine direct from them I believe its the Zero screen you want.
"If in doubt flat out"
Colin McRae
Bluemoon
posted on 27/8/13 at 09:53 AM Reply With Quote
Others will fit I have a Westfield one on mine (fail to remember if narrow or wide-bodied), not perfect but looks o.k, MK one is higher.. O.k on mine as I have Caterham seats and these are at quite a rake angle, so this is not an issue for me.
With home-made weather gear (apologies for photo quality!)
Dan
[Edited on 27/8/13 by Bluemoon]
whitestu
posted on 27/8/13 at 10:54 AM Reply With Quote
I have Caterham screen on mine an it fits really well.
Stu
Not Anumber
posted on 27/8/13 at 11:27 AM Reply With Quote
I put a GBS Zero screen on mine and it fits a treat.
In my case I fitted the screen further back on the scuttle than standard but only did this because I was fitting the Zero weather gear at the same time (The Indy cockpit is slightly longer than on the Zero but fits fine if the screen is mounted an inch or so further back). Again it gave a good result and the wipers fit nicely through the vertical 'step' on the Indy scuttle where the screen would normally be mounted, looks as though it was made to fit that way.
Brackers
posted on 27/8/13 at 06:34 PM Reply With Quote
Cheers guys, also want to fit side screens (doors) assume should still fit ok? Can get these from GBS too? After a black frame!
Not Anumber
posted on 28/8/13 at 09:01 AM Reply With Quote
If you are fitting the GBS doors and/ or hood to an Indy you will need to mount the base of the screen further back.
Ive posted some pictures on my photo archive. PM me with your email address if you need me to take some more.
Brackers
posted on 28/8/13 at 07:24 PM Reply With Quote
New Topic New Reply
