<<  1    2  >>
Author: Subject: Sloppy/hard to engage gears after long run
steve8274
posted on 15/9/13 at 07:33 PM Reply With Quote
Hi all
My type 9 seems to have developed a problem. After using the car for long period, the gearbox goes sloppy and its hard to engage any gear. Once the car cools, gears fine again.
Used car yesterday and was on motorway for around 20 miles travelling at 70ish. When I came to end of slip road, problem encountered.
Any ideas?
six mad
posted on 15/9/13 at 07:42 PM Reply With Quote
Has the box had a oil change recently or level check?
steve8274
posted on 15/9/13 at 07:47 PM Reply With Quote
Car has done just over 1000 miles since last change. Was all done before car went on road a little under 2 years ago. Checked oil level yesterday after it had cooled and all fine.(I thought it may have been low too)
teegray19
posted on 15/9/13 at 07:59 PM Reply With Quote
Cable or hydraulic clutch?
steve8274
posted on 15/9/13 at 08:28 PM Reply With Quote
Cable operated
ashg
posted on 15/9/13 at 09:05 PM Reply With Quote
wrong oil?
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
teegray19
posted on 15/9/13 at 09:32 PM Reply With Quote
Your clutch cable needs adjusting. Wouldnt be surpirsed if its on its way out.
Adjust it a touch and you should find selection of gears alot easier.
steve8274
posted on 15/9/13 at 09:43 PM Reply With Quote
Pretty sure it's the right oil in. Comma 75/90 gl4?
Thought about clutch cable but why would it go ok once engine had cooled down?
teegray19
posted on 15/9/13 at 09:45 PM Reply With Quote
Bit of cable heat soak. My old one used todo the exact same. Even more so when it was exhaust side.
steve8274
posted on 16/9/13 at 07:55 AM Reply With Quote
Ok. Is there a way to confirm this or just replace and try?
My exhaust is on other side
teegray19
posted on 16/9/13 at 07:57 AM Reply With Quote
id just adjust it a little and if it becomes easier after the same length drive your on to a winner,
id keep a spare cable handy anyways, just in case!
steve8274
posted on 16/9/13 at 08:05 AM Reply With Quote
Great. Will do
Thanks for help
mitch2b
posted on 16/9/13 at 08:11 AM Reply With Quote
hi steve,
its they old problem of heat on the cable, the inner sleeve is coated and when warm, drags on the inside,, needs a sleeve or re route,
Mitch
teegray19
posted on 16/9/13 at 08:31 AM Reply With Quote
wd40 down the bore can normally do it aswell
steve8274
posted on 16/9/13 at 01:25 PM Reply With Quote
So I nipped home in my dinner time to check cable. Was a little slack but not a great deal. However I have noticed the gears are sloppy again even with engine gearbox cold. I didn't even start engine.
The gearbox feels like there are no "gates" for the gears( sorry don't know how else to explain) there is no definate position for any of the gears. Could almost stir the gearstick round if that makes any sense.
Are there supposed to be some "gates" in gearbox? Could this have failed? How do I check?
teegray19
posted on 16/9/13 at 01:57 PM Reply With Quote
Starting to sound less of an easy fix...
Can you check if you gear stick is properly scrwed into the box? When your there take it out and look at the selection fork.
mitch2b
posted on 16/9/13 at 03:06 PM Reply With Quote
hi steve, theres a plastic "saddle " under the gearlever , this could be broke or worn, only few quid to fix, . remove the three screws holding lever in , remove and check its in one piece beneth it,
mitch
steve8274
posted on 16/9/13 at 03:46 PM Reply With Quote
Ok. Will see if I can look when I get home.
Can all this be done with just tunnel off or does the box need to come out.
How do you get to them?
mitch2b
posted on 16/9/13 at 03:51 PM Reply With Quote
just the gear lever out, no need to strip box out ,
this is what your looking for beneath the gear lever
FORD TYPE 9 GEARBOX GEARSTICK SADDLE BUSH Sierra kitcar quaife tran-x westfield
mitch
[Edited on 16/9/13 by mitch2b]
posted on 16/9/13 at 03:54 PM Reply With Quote
If you can see the top of the gearlever mount (triangular plate, with 3 screws) then you can get at the plastic saddle. Undo the screws, lift out the gearstick, then look at where the stick engages - there will be a plastic contrivance there. This can be pulled straight upwards, as it's only held on by a 'clip' moulding. It's obvious once you pull at it!
While you're there, put the box into 1st gear and take a look at the roll pin that holds the thing that the saddle clips on to - make sure that there is a roll pin, and that it's seated nicely. It's not likely to have come out or moved, but it's a cheap and simple thing to look at.
Note: I go with the 'clutch adjustment' theory...
steve8274
posted on 16/9/13 at 04:42 PM Reply With Quote
Thanks to all. Will look later. Hopefully be able to see the screws without any major drama.
With reference to clutch adjustment, surely when I tried to put car into gear without engine on or clutch engaged, it would feel like a normal gearbox should do? Mine isn't like that. Can't tell if in a gear and can turn it like a spoon turning in a pan.
posted on 17/9/13 at 12:18 PM Reply With Quote
It might be as simple as the 3 screws on the gearstick being loose!
RichardK
posted on 17/9/13 at 12:46 PM Reply With Quote
Was thinking the same David but was going to ask if he's using a gear lever extension that has rattled loose.
R
Gallery updated 11/01/2011
steve8274
posted on 17/9/13 at 01:17 PM Reply With Quote
That would be nice if simple job like that. Not using extension lever. All original.
Never got chance to look last night. Hopefully will tonight and report back.
steve8274
posted on 17/9/13 at 08:33 PM Reply With Quote
Just to close this post.
Took tunnel off and the gearstick was just about being held on with one bolt! Got some more bolts and tightened down with some nut lock and all seems good.
Thanks for help.
<<  1    2  >>
