Author: Subject: Merc engine cuts at 4400rpm...
fha772
posted on 18/9/13 at 01:31 PM Reply With Quote
Hi all,
I've got a bit of a problem with my Merc.
It revs up ok, but when it gets to about 4400rpm, the ignition cuts, like it's hitting a rev limiter.
I'm stumped, I've replaced virtually everything on the ignition, and I'm running out of ideas.
I need to get it sorted by tomorrow, or I'll be taking my Merc lorry round Blyton on Friday!!
Cheers Frank.
http://www.ppcmag.co.uk/forum/viewtopic.php?f=47&t=6743&start=105
bigrich
posted on 18/9/13 at 03:18 PM Reply With Quote
Sounds like the cam position sensor. Does it crank longer than normal before firing. Also is cam tining correct? Or if belt driven the tension correct
fha772
posted on 18/9/13 at 03:25 PM Reply With Quote
Sorry, should have said, it's a 1982 2.8 straight 6, with Bosch electronic distributor ignition.
So it hasn't got a cam sensor, or anything like that, it's only 1 step away from points ignition.
mookaloid
posted on 18/9/13 at 03:43 PM Reply With Quote
Fuel pump? struggling to cope with higher fuel delivery? restriction in the fuel line?
Just a few ideas - might be rubbish!
fha772
posted on 18/9/13 at 03:53 PM Reply With Quote
No it's definitely ignition, as I've had the timing strobe on it, and the light starts cutting/pulsing when the engine hits 4400rpm.
alfablack
posted on 18/9/13 at 03:56 PM Reply With Quote
Hi is it automatic
owelly
posted on 18/9/13 at 04:04 PM Reply With Quote
Does it have a mechanical rev limiter type rotor arm? If so, glue it so it can't move.
Is there constant power to the +ve of the coil and pulsed to the -ve side?
Volvorsport
posted on 18/9/13 at 06:17 PM Reply With Quote
rev limiter in the rotor arm ? spring goes soft ..... vw golfs , maybe the same .
www.dbsmotorsport.co.uk
getting dirty under a bus
fha772
posted on 18/9/13 at 06:30 PM Reply With Quote
Nope,
I've swapped the rotor, it made no difference.
I've checked the power to the coil, that's fine.
The spark is perfect.
It looks like the distributor is buggered, if the 1 off my spare engine isn't any good, it looks like I'll be looking for passenger rides on Friday
owelly
posted on 18/9/13 at 06:55 PM Reply With Quote
Bring it along anyway. You can play with my Turd whilst I fix your barge.....
Nickp
posted on 18/9/13 at 07:01 PM Reply With Quote
Agreed. So, we need a timing light and a box of matches then?
fha772
posted on 18/9/13 at 07:16 PM Reply With Quote
Well, I've got the timing light...
T66
posted on 18/9/13 at 07:17 PM Reply With Quote
You have such a way with word Sir.....
fha772
posted on 18/9/13 at 09:56 PM Reply With Quote
Well, it's not looking too promising, I've just come in, while getting the timing set up, the starter has died, and I think the over-complicated fuel pump relay has spat it's dummy out again.
I'm going to have tomorrow on it, maybe into the night again, if I can't sort it, I'll come Friday morning and try to blag as many passenger rides as I can.
I think I'm going to have to spend some serious time on it this winter...
Nickp
posted on 19/9/13 at 05:05 AM Reply With Quote
Matches on standby
You may as well fetch it over teatime then at least you can have a beer whilst trying to fix it mate
owelly
posted on 19/9/13 at 05:10 AM Reply With Quote
I'll bring an axe.
Nickp
posted on 19/9/13 at 06:26 AM Reply With Quote
At least we can have a decent fire
fha772
posted on 19/9/13 at 06:30 AM Reply With Quote
I'll be over tonight, I just won't have a car
It's just too much work for today, along with the stuff I've got to do for the chippy, and the fair, before I leave.
Edit: I wonder if Richard will let me run the lorry...
[Edited on 19/9/13 by fha772]
adithorp
posted on 19/9/13 at 06:44 AM Reply With Quote
That's a shame, especially after all the work you've put in to organise it. I can't see you having any problem blagging rides though.
http://jpsc.org.uk/forum/
Nickp
posted on 19/9/13 at 06:53 AM Reply With Quote
If you deffo aren't bringing it then you may as well fetch t'audi Or swing by Gaz's and trailer the MR2 down there maybe?
russbost
posted on 19/9/13 at 08:10 AM Reply With Quote
Does it have vac advance fitted? If so disconnect it & see if that stops it, it may be that as the baseplate hits a particular position it's opening a break in the wiring? Otherwise if this is the Bosch distributor with the little ignition amp attached to the side of the dizzy they were notorious for giving problems (the amp I mean)
posted on 19/9/13 at 08:16 AM Reply With Quote
Is it time for a nodiz ?
fha772
posted on 21/9/13 at 11:23 PM Reply With Quote
After spending the day thinking about it, I think the Merc needs an ignition upgrade...
...the question is, what do I go for? Megajolt? Nodiz? Or, another?
Volvorsport
posted on 21/9/13 at 11:32 PM Reply With Quote
123 ignition?
