r1_pete
posted on 22/9/13 at 05:28 PM |
ITBs and Servo take off
I'm progressing well with the ITB manifold for the E Type, I'm now thinking about the servo take off.
I could use a single barb on one of the runners, but, I have a vacuum point on each runner, which will be linked together via a 15mm tube for MS MAP,
and for the vac gauges to balance the bodies.
Question is could I run the servo off these too, each take off is 3mm bore, my thoughts:
Standard jag single take off from the plenum is 7mm bore giving an area of 38.5 mm sq, I have 6 take offs at a combined area of 42.4 mm sq.
Would I have sufficient air flow for the servo? the car does have a vacuum reservoir too.
clairetoo
posted on 22/9/13 at 05:49 PM |
Om my Mx5 V6 I run a single vacuum lime from one `body to the servo , with the other 5 blanked off - and the brakes are fine
Its cuz I is blond , innit
Claire xx
Will weld for food......
rdodger
posted on 22/9/13 at 07:45 PM |
You can run the vac to a manifold then distribute from there?
