Dickyboy
| posted on 23/9/13 at 10:06 AM |
weber spacer query
I am sure this has been asked, but I can't find it.
How important is the thick "phenolic" spacer between carb and manifold, what are the pitfalls of leaving it out?
Macbeast
| posted on 23/9/13 at 12:47 PM |
It's probably to isolate the carb from the engine heat. Without it the fuel in the carb may boil / evaporate
skibikejohn
| posted on 23/9/13 at 01:41 PM |
The spacer is to limit the carburetor vibrating with the engine. The carb should be able to move slightly, relative to the engine / manifold. I would
recommend installing the spacer as it made a difference on my car.
scimjim
| posted on 23/9/13 at 03:00 PM |
Not sure how it limits vibration
It's to prevent fuel vaporisation in the carb through heat transfer. It's also probably part of the inlet tract length design?
| posted on 23/9/13 at 06:17 PM |
You are thinking of Misab plates, or similar systems with large O-rings. I suspect the OP is talking about a solid phenolic spacer which is used for
heat isolation and I also suspect he may be talking about a downdraught carb as I've never seen phenolic spacers used with DCOEs.
Not Anumber
| posted on 30/9/13 at 06:02 PM |
clearence would certainly be better without the spacer under the downdraught carb. Not sure what it's there for, always assumed it was to limit
heat transfer so never tried removing it.
Dingz
| posted on 30/9/13 at 06:35 PM |
Ran mine without one for years without apparent problems, to increase bonnet clearance.
went on and on.
dave r
| posted on 30/9/13 at 08:24 PM |
i ran mine, without problems also.... rekon i have one though if you think you need one ?
(assuming its a 32/36 or dgas ?)
[Edited on 30/9/13 by dave r]
I'd love to give my imaginary friend a great big hug,
but this jacket makes it impossible.
