Author: Subject: Fuel Gauge?
Cadburys Man
posted on 28/9/13 at 09:08 PM Reply With Quote
Fuel Gauge?
My Stuart Taylor Locosaki doesn't have a fuel gauge and being a noob have no idea how to go about getting one sorted, any of you guys got any ideas/info/suggestions?
Thanks in advance
Daz.
Stuart Taylor ZX9-R Locosaki
Davey D
posted on 28/9/13 at 09:44 PM Reply With Quote
I made my own fuel gauge using the circuit diagram from here: http://www.mez.co.uk/ms13.html
Cadburys Man
posted on 28/9/13 at 10:52 PM Reply With Quote
Thanks for that, it's much appreciated but i'm even more confused now!! lol, wouldn't know where to bloody start with all that :-/
Daz.
theprisioner
posted on 28/9/13 at 11:11 PM Reply With Quote
If that confuses you try this:
http://www.alastair-reynolds.pwp.blueyonder.co.uk/fuelsystemlinearizer/index.htm
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
Cadburys Man
posted on 29/9/13 at 08:00 PM Reply With Quote
Haha i must be thick cos even that is too technical for me :-/
Does anyone sell a kit that i can just fit thats simple??
Daz.
Scuzzle
posted on 29/9/13 at 08:14 PM Reply With Quote
If you need a fuel sender try and get a design that is not affected by fuel in the tank sloshing about. I retro fitted a digital gauge but used the factory sender and it's a case of sharp LH turn fuel tank of fuel, sharp RH turn empty, just fluctuates too badly.
If I was designing it from scratch I would look at rectifying this, no idea what I would need though just making you aware of it.
[Edited on 29/9/13 by Scuzzle]
Cadburys Man
posted on 29/9/13 at 08:32 PM Reply With Quote
Does anyone know if this would be any good?
12V FUEL GAUGE &' TANK SENDER UNIT KIT SPECIAL PURCHASE
Daz.
theprisioner
posted on 29/9/13 at 10:24 PM Reply With Quote
https://www.spiyda.com/magento/index.php/vehicle-electronics/fuel-gauge-electronics/8-led-fuel-gauge-anti-slosh.html
Obviously reading is a problem!
blakep82
posted on 29/9/13 at 11:36 PM Reply With Quote
Well, not really... you set it up how you want it, using the trim screws.i got the 4 led one, and he built anti slosh in for a few extra quid. I've got a 35ltr tank, and only really wanted a low level light, so I want mine to show full til its only half full,
So start with an empty tank, decide how much fuel you want left when the low level light switches on, 30 miles is about usual for production cars, 30mpg perhaps, so put in 5ltrs, adjust til the last light goes off and switches to the low level. 5 more litres, trim for 2 lights on,, 5 more litres, then set for all 3 leds on (3 level lights, 1 low level light)
________________________
Cadburys Man
posted on 29/9/13 at 11:38 PM Reply With Quote
So i'm guessing if i bought one of those i have to find the right sender and fit it into the tank somewhere?
Daz.
Cadburys Man
Daz.
owelly
posted on 30/9/13 at 08:51 AM Reply With Quote
I bought a gauge and sender off Ebay for about £20. It was for a boat. The sender has an adjustable float arm and easy instructions to set it up. You'd have to check if your tank has baffles. You also need to cut a hole in the tank but again, it had instructions.
http://www.ppcmag.co.uk
owelly
posted on 30/9/13 at 09:24 AM Reply With Quote
http://pages.ebay.com/link/?nav=item.view&id=370682347196
mcerd1
posted on 30/9/13 at 12:02 PM Reply With Quote
Daz.
you'll need a sender in the tank for any gauge - which sender you get will depend on what best suits your tank
has your tank got a space for a sender already ? if so which type of sender mounting is it made to suit ?
there are a few different versions of the 'standard' / generic senders, some with 5 bolts, some with 6..... and so on
the float arm ones are fine for most folk, but if you've got lots of baffles and things inside the tank then the 'dip tube' style senders will work better (but not as cheap)
after that all you need is a compatible gauge - how fancy a gauge is up to you, you could even just fit a warning light and no gauge at all
Scuzzle
posted on 30/9/13 at 01:48 PM Reply With Quote
I've done that with mine, I tinkered around with the voltage resistance settings but could never get it right on my digital gauge so an empty tank is 0 and a full tank is 100. On mine the best I can get is 87 for a full tank and 7 for empty which is not ideal.
So I drilled a couple of holes into the side of the tank and fitted float switches and a couple of LED lights on the dash, one comes on when I have 2 gallons left and the second one comes on when I'm down to the last gallon. Purely so I don't end up stuck somewhere out of fuel.
[Edited on 30/9/13 by Scuzzle]
mcerd1
posted on 30/9/13 at 03:41 PM Reply With Quote
the one supplied with my dax is supposed to be adjustable - turns out that means you bend the float arm till it works - crude but effective
sounds like your sender just doesn't quite suit your tank
the baffles in the replacement tank my dad got for his landrover clash with the float arm of the sender - so it never shows more than 3/4 full (and now its all assembled its too much of PITA to sort it )
[Edited on 30/9/2013 by mcerd1]
Scuzzle
posted on 30/9/13 at 06:25 PM Reply With Quote
On my fuel gauge there are thin wires on the back you are meant to cut to match the fuel sender, one for Ford, one for Vauxhall and a third one but none of them seem to do the job as I've tried cutting and rejoining them all.
Cadburys Man
posted on 30/9/13 at 09:42 PM Reply With Quote
Daz.
All i've got by the looks of it is an aluminium rectangular tank with the filler on the top in the middle with nowhere to mount anything so it looks like it needs cutting out :-/
