AlexXtreme
| posted on 8/10/13 at 04:34 PM |
Suspension bolts
The bolts for my back suspension arms are very rusty... (they are getting on for 13years old) and I am about to take off the arms and give them a good
clean off and repaint. Has anyone used stainless steel bolts for the suspension? The rest of the chassis is st. steel (it is a quantum xtreme), so I
thought why on these bolts. I know st. steel is not as strong as steel bolts, esp 8.0 or 10.8 but they are held on with 4 x M12 bolts and the load can
not be that high on these cars...
Look forward to any comments / ideas
Cheers Alex
FuryRebuild
| posted on 8/10/13 at 04:47 PM |
generally, stainless doesn't like reciprocating loads - they're great in tensile but are brittle as a result and will work-harden much
sooner.
You need the right mild steel bolt. I asked a similar question here a while ago which prompted me to do some research
www.furyrebuild.co.uk
AlexXtreme
| posted on 8/10/13 at 04:56 PM |
Thanks!
Did you get bolts with any kind of coating or did you accept that they will rust after a while?
Driving in the winter there is plenty of salt on the road :-(
Alex
designer
| posted on 8/10/13 at 05:39 PM |
Never use stainless steel bolts in any critical area, use Grade 8.
DavidM
| posted on 8/10/13 at 09:41 PM |
Use bright zinc plated (bzp) bolts. They are grade 8.8 as standard and although they will dull, they won't rust.
Proportion is Everything
AlexXtreme
| posted on 9/10/13 at 07:22 AM |
thanks Dave... will try a local supplier down the road and see what they have.
Alex
b14wrc
| posted on 9/10/13 at 11:36 AM |
Look for these on ebay:
M12 M14 M16 Hex Head Bolt Steel Grade 8.8 - Zinc Plated Hexagon Head Bolt
I bought 70mm versions for mine and they are perfect. The guy who runs the shop is really helpful too and delivery is very quick.
Rob
20vt powered rear engined locost
AlexXtreme
| posted on 9/10/13 at 11:42 AM |
Hi Rob,
Thanks for this and a useful link! unfortunately mine are all M10... but found a similar side that offered backs of 4 x M10.
have bookmarked the ebay sites for further ref. though..
Alex
b14wrc
| posted on 9/10/13 at 12:17 PM |
No problem. All my bolts have come from them, recommend them.
Rob
40inches
| posted on 9/10/13 at 01:36 PM |
I've found Screwfix to be good for HT bolts Plated M10
AlexXtreme
| posted on 9/10/13 at 01:41 PM |
Thanks - had a look - unfortunately my car needs small quantities of (oe 2 and 4 off) of different lengths. Screwfix do packs of 10 or 100.
loggyboy
| posted on 9/10/13 at 01:54 PM |
Get bulk long ones and cut them down?
To be fair, at screwfix (or often cheaper, toolstation) prices you will probably pay les for 10 than you will in total for 4 singles at B&Q or
homebase or a bolt specialist.
Mistral Motorsport
