Author: Subject: Ms2 or Ms3?
mackei23b
posted on 17/10/13 at 06:32 PM Reply With Quote
Ms2 or Ms3?
Hi there
I've used an ms2 with a k series before, now my latest project is a Duratec in a Caterham. Should I go for a MS2 again, or should I go for an MS3?
Help me decide, and why!
Ian
big-vee-twin
posted on 17/10/13 at 07:18 PM Reply With Quote
MS2 more than good enough for running a Duratec.
http://www.triangleltd.com
BaileyPerformance
posted on 17/10/13 at 07:32 PM Reply With Quote
MS2 is fine, MS3 gives you fully sequential injection which you do not need. Plus MS2 is cheaper than MS3
daxtojeiro
posted on 18/10/13 at 05:57 AM Reply With Quote
You can run an MS2 sequentially (fueling and ignition) on an engine up to and including a 4cy.
But the MS3 code is far more advanced than the MS2 code, especially the latest version which is in beta format right now.
For most users an MS2 is plenty good enough, indeed some of the MS3 features are being back ported into MS2, so its still being developed, but if you can go for an MS3 with an MS3X card then thats the best option, as it wont leave you wanting for anything, it has everything you could imagine all built in, but the cost is a fair bit higher,
thanks
Phil
TrophyJem
posted on 18/10/13 at 06:54 AM Reply With Quote
I'm just about to replace the pinto in my westy with a duratec.
I'll probably go the ms2 route by building a kit. Not that I'm ready for that stage yet.
I can allways upgrade later if I feel the need and sell the ms2 on.
baz-R
posted on 9/11/13 at 08:08 PM Reply With Quote
ms2extra now has itb mode for throttle bodies
