Author: Subject: Fuel tank level :-/
Cadburys Man
posted on 29/10/13 at 07:51 PM Reply With Quote
Fuel tank level :-/
Ive fitted a new pipe on the tank where it indicates how much fuel is in the tank then I went to fill it up but when I got back and looked to check the level there was no fuel in the pipe even tho the tank is full, I'm confused lol.
[Edited on 29/10/13 by Cadburys Man]
Stuart Taylor ZX9-R Locosaki
bill132hotrod
posted on 29/10/13 at 08:02 PM Reply With Quote
fuel level pipe
Hi ya
Have you got any pictures of what you done.?
PERSEVERANCE is the word of the week. Stick with it the results are SWEET.
jacko
posted on 29/10/13 at 08:14 PM Reply With Quote
Is the pipe only connected at the bottom of the fuel tank ? it has to also be connected at the top too, it sounds like you have air trapped in the pipe
Jacko
Cadburys Man
posted on 29/10/13 at 08:21 PM Reply With Quote
Yes it's connected at both the top and the bottom :-/
40inches
posted on 29/10/13 at 08:28 PM Reply With Quote
If the tank is full, the tube may be full of petrol and not visible, keep checking as you use it, the top of the fuel level should become visible as the level goes down.
jacko
posted on 29/10/13 at 08:31 PM Reply With Quote
It may be a daft idea but if the tank is full that will mean the pipe is full so to you it will look empty If you get what i mean
If you only half filled the tank you would see the height half up the pipe
40Inches beat me to it
[Edited on 29/10/13 by jacko]
Cadburys Man
posted on 29/10/13 at 08:49 PM Reply With Quote
I'm beginning to think u 2 are right :-/ lol
I'll check it in the morning
Thanks guys!!
Daz.
