New Topic New Reply
Author: Subject: Welding an insert into a tube
Slimy38
posted on 10/11/13 at 11:17 AM Reply With Quote
I have some threaded inserts for my suspension, but I'd like to reinforce them by welding them into some tubing. What's the best way to do it? Logic would suggest the only place they can be welded is on the end, but I'm wondering whether that will actually be weaker than simply using the inserts as they are. They are to be used for the adjusters, so I believe the forces will be pulling and pushing. Does that mean I might simply pull the adjusters straight out the tube?
Any thoughts?
[Edited on 10/11/13 by Slimy38]
theprisioner
posted on 10/11/13 at 11:46 AM Reply With Quote
One possible solution I have used several times. I drill one or possibly 2 (is better) 8mm holes in the side of the tube and spot weld the insert to the tube then remove excess weld afterwards.
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
omega 24 v6
Drill the tube sides and plug weld them.
doobrychat
posted on 10/11/13 at 11:47 AM Reply With Quote
slice the top and bottom of the tube.. weld insert on the end then the 2 sliced area to support top and bottom the length of the insert.. I did this when i converted my top wishbones to take rose joints..
CNHSS1
posted on 10/11/13 at 11:55 AM Reply With Quote
yup, +1 from me. weld the seam as you mentioned, then plug weld a couple of holes as above
Slimy38
posted on 10/11/13 at 01:24 PM Reply With Quote
Holes it is then! I just hope I don't end up going through the insert, I don't fancy having to clean up the threads afterwards.
Thank you all.
posted on 10/11/13 at 02:36 PM Reply With Quote
Thank you all.
If you weld a threaded insert then the chances are high that you will need to run a tap through it afterwards.
Are these inserts for the wishbones or trailing arms so you can install rod ends for adjustment? If so, how were you planning to fix them in without welding (i.e. "using the inserts as they are" )?
[Edited on 10/11/13 by MikeRJ]
Mistron
posted on 17/11/13 at 10:10 PM Reply With Quote
It's better practice to cut the end of the tube at 45 degrees and weld round the cut as it gives a larger contact area and also spreads the load along the length of the bush, rather than concentrating it all around the bus at one point in its length
Al
iank
posted on 18/11/13 at 08:07 AM Reply With Quote
Al
Even better to make two cuts as you get more weld on both sides of the insert.
Anonymous
Slimy38
posted on 18/11/13 at 10:14 AM Reply With Quote
They are for rod ends, so yes they would have been welded anyway. I just meant either welded up as they are, or welded inside tubes which are then used to make up the wishbones.
New Topic New Reply
