Author: Subject: where to buy Clamping Studs?
dan_g8
posted on 16/11/13 at 11:21 PM Reply With Quote
Hi i require about 20 x m5 Clamping Studs like the picture below with the hex part for a spanner, i have looked everywhere but cant find m5 ones anywhere! can someone point me in the right direction?
thanks
[Edited on 16/11/13 by dan_g8]
ReMan
posted on 17/11/13 at 09:38 AM Reply With Quote
Why do you specifically need the hex part?
As opposed to just using 5mm threaded bar and a pair of nuts locked to fit it?
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
dan_g8
posted on 17/11/13 at 10:11 AM Reply With Quote
It's for a project that I'm working on, I need to join 2 bearing blocks together. They have tapped holes but they don't go all the way through to the other side. The studs a no go because of this, one side would need to be left hand threaded and the other right handed to pull the blocks together when tightened?
bigrich
posted on 17/11/13 at 01:34 PM Reply With Quote
Do a search on Ebay for M5 linkage screw. May be cheaper to have a small batch made by a local machine shop or a fellow locoster for beer vouchers etc
acb2713
posted on 17/11/13 at 04:11 PM Reply With Quote
Perhaps these people might be able to help?
MARYLAND METRICS
You'll need some time to go through all their products.
Regards,
Albert
ReMan
posted on 17/11/13 at 10:12 PM Reply With Quote
Oh! Sounds complicated!
Is there not a simpler way?
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
