Author: Subject: How to increase Striker's front camber?
sky
posted on 14/12/13 at 06:12 PM Reply With Quote
Hi everyone,
How can I increase the front negative camber of my Striker with Sierra's hubs and inboard suspensions?
Have I to do something to the top balljoint?
pekwah1
posted on 14/12/13 at 06:27 PM Reply With Quote
Surely you'd have to shorten the rocker arm or lengthen lower arm?
posted on 14/12/13 at 06:52 PM Reply With Quote
Adjustable lower arm would be by far the easier way.
sky
posted on 14/12/13 at 07:05 PM Reply With Quote
Can you upload a pic of the adjustable rocker arm?
Andy S
posted on 14/12/13 at 07:31 PM Reply With Quote
Adjustable lower arm of a Fury
loggyboy
posted on 14/12/13 at 07:44 PM Reply With Quote
Current (well 2011) Raw wishbones are nearly identical
Mistral Motorsport
sky
posted on 14/12/13 at 07:49 PM Reply With Quote
Thank you everyone.
I'm desperate, I've the not adjustable version
posted on 14/12/13 at 07:55 PM Reply With Quote
Rose joint on the inboard ends of the lower wishbone would be the easiest way.
The downside of adjusting the lower arms rather than the uppers is any adjustment has a bigger effect on the toe-in.
ashg
posted on 14/12/13 at 08:28 PM Reply With Quote
Originally posted by sky
Thank you everyone.
go to raw and buy the adjustable lower wishbones im sure they will be happy to sell you a pair.
[Edited on 14/12/2013 by ashg]
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
jeffw
posted on 14/12/13 at 09:41 PM Reply With Quote
They will....I bought a pair for my Phoenix last year from them. The Striker/Phoenix arms are not the same as the Fury strangely.
zilspeed
posted on 14/12/13 at 11:48 PM Reply With Quote
Remember
Whatever you do will have an effect on bump steer too.
It might get rid of it if you currently have it.
It might give you it if you don't have it just now.
Why do you need to change the camber ?
sky
posted on 15/12/13 at 12:28 AM Reply With Quote
I've not excessive bump steer but I notice often an annoiyng understeer at high speed on the track....I also checked tyres temperature and it appears I need more negative front camber.
sky
posted on 15/12/13 at 01:12 PM Reply With Quote
I've only one end adjustable but I think the margin of regulation is minimal.
zilspeed
posted on 15/12/13 at 01:45 PM Reply With Quote
having thought about it overnight, I was talking bollocks.
If your inner wishbone pivots stay the same, which they will, and your rack stays the same, bump steer will not be affected.
I do love how your minimal camber adjustment with those bones also adjusts castor angle, whether you like it or not.
Surprisingly short sighted by whoever decided that.
posted on 15/12/13 at 04:44 PM Reply With Quote
You could probably get those wishbones modified to add a rose joint (rod end) to replaced the fixed bush.
sky
posted on 15/12/13 at 05:43 PM Reply With Quote
Yes, I'll try this route.
I bought these lower wishbones this year from Raw, if only I had known...
posted on 15/12/13 at 10:17 PM Reply With Quote
Increasing the caster also gets the inner edge of the tyre to work more. bringing the temperature up.
sky
posted on 16/12/13 at 12:37 AM Reply With Quote
Thanks.
I have about 8 degrees of castor now
