Author: Subject: Steering Wheel Boss
IainL
posted on 21/1/14 at 05:41 PM Reply With Quote
Steering Wheel Boss
I have just brought a B&G quick release steering wheel adaptor but now may paddle shift is to far away from the steering wheel
I have tried to slide the paddle shift closer to the steering wheel but now it fowls against the boss when you pull the paddle forward
Is there a narrow steering wheel boss available anywhere which I can use to connect the Sierra column to the quick release adaptor?
Iain
renetom
posted on 22/1/14 at 08:29 AM Reply With Quote
paddles
Hi
We had the same problem when we fitted a collapsible boss
for the iva , so made a pair of black nylon extenders which worked a treat
Took them off after IVA, still have them, if you have the same paddles,
you can have them.
This is our paddle shift.
Flappy modification
Flappy modification
& these are the extenders, you need 4 long s/s nuts & bolts.
