Author: Subject: Radiator Grille Fitment?
Cadburys Man
posted on 21/1/14 at 05:58 PM Reply With Quote
I've treated myself to a new front grille but the pins that are used to mount it go vertical instead of horizontal so obviously I need to drill the fibreglass so I can mount it but I've no idea wot I can use to keep it in place and not slip down, does anyone have any ideas?
Daz.
Stuart Taylor ZX9-R Locosaki
Cadburys Man
posted on 21/1/14 at 05:59 PM Reply With Quote
[/URL]
[Edited on 21/1/14 by Cadburys Man]
SPYDER
posted on 21/1/14 at 08:09 PM Reply With Quote
Looking at the grille at its widest point it doesn't look like it will go back into the recess very far. Is that right? If it does fit right back into the recess then I would do the following...
Grind off the inch wide flat surface completely. They look far better without it IMHO. This will also get rid of the existing holes.
Drill the two lower holes.
Fit lower grille mounting prongs into drilled holes. The top prongs will require slots to slide into. They wont be seen. Centralise grille and measure how much pokes through lower holes.
Remove grille.
Put some GRP under the lower holes so that when the holes are re-drilled to the required depth they become blind holes.
Refit grille. Should now sit at correct height.
Slide top prongs into slots. GRP a washer in place over the top prong.
And paint inside of nosecone black if not already done.
Bit of a faff I know. Straight off the top of my head.
But you did ask.
jacko
posted on 21/1/14 at 09:13 PM Reply With Quote
When the grill is in place it looks like it will be over the 4 holes in the fiber glass so put 4 small tie wraps though the glass and round the grill
bigrich
posted on 21/1/14 at 10:23 PM Reply With Quote
What about small pieces of tube or "o"rings used as spacers on the grill to support on the grp. You can shim it up and down to get a best fit then maybe star washers to final fix inside the nose return edge
SteveWalker
posted on 21/1/14 at 10:55 PM Reply With Quote
How about drilling two holes for the bottom pins, removing the top pins and cutting diagonal slots into two stainless-steel grub screws; hook the grub screws over the top rail of the grill and put them through the existing holes in the grp; star washers and nuts on the back?
Cadburys Man
posted on 23/1/14 at 06:03 PM Reply With Quote
Thanks for the advice guys, i drilled vertical holes out then on the inside i slotted silicone hose over the pins then put domed star lock washers over the ends
Looks pretty neat and secure
Daz.
40inches
posted on 23/1/14 at 06:16 PM Reply With Quote
Daz.
I'm proud of yer! Where is it going to end, what next?
However without photo's, it didn't happen
Cadburys Man
posted on 23/1/14 at 06:49 PM Reply With Quote
Daz.
LOL, thanks Dave )
I'm proud of myself tbh cos i'm crap at ANYTHING like that lol. I'm NOT attempting the other bigger jobs :-/ I'm saving them for someone a bit more professional lol
Anyway photo's............................
And one more lol.............................................
