Author: Subject: very frustrated
Dooey99
posted on 28/1/14 at 08:45 PM Reply With Quote
very frustrated
vinyl wrapping infuriates me. why cant it just work without getting little tiny creases in at the edges? why do i burn my fingers on the heat gun? why cant i magic the panels into carbon fibre?
rant over.
very angry.
Less weight more speed, more power more speed
If in doubt, give it a clout
bi22le
posted on 28/1/14 at 09:10 PM Reply With Quote
Get somebody to hold the gun for you so you can get more ambient heat on it from further away. This leaves you both hands and more time so you dont feel rushed.
Creases on the sides - This I think is because you are stretching it too much before laying it. Kind of over stretching it. Again having an extra hands help. Also imagine in your head the panel is 2" bigger than it is. This way you get the creases off of the panel and therefore cut off once trimmed.
One more thing, the flatter the panel the less heat you need. For flat panels spray lots of water on the vinyl and panel and use a soft windor squigy or sponge to press air out.
Lots of Youtube clips to see the pro's do it.
Keep calm and be safe in the knowledge that at least its not too expensive. Rip it off and start again if req.
Good luck
Please read my ring story:
Dooey99
posted on 28/1/14 at 09:17 PM Reply With Quote
my mate just bought a hydro dipping kit so might get everything dipped if his tanks are big enough.
Matty_o
posted on 28/1/14 at 09:24 PM Reply With Quote
As above having some one holding the heat gun helps a lot. I found using the best material helped as well if doing large pieces and bits with bends,corners ect the cheap stuff is un forgiving. Also if using carbon effect wrap be carefull not over stretch as you will distort the weave and will look a little odd.
If wrapping two separate parts that go side by side remember to to have the weave going the same direction.
Take your time to get it wright however frustrating it can/will be, I wrapped the whole of my last car in carbon (mk) and it looked bloody awsome
Dooey99
posted on 28/1/14 at 09:29 PM Reply With Quote
i cant do the the wheel arches the curve outer edge is a pig and for someone with very little patients like myself if it is annoying!
Slimy38
posted on 28/1/14 at 09:53 PM Reply With Quote
This. You WILL get creases in the vinyl no matter what you do to prevent it. However, if those creases are in the extra bit that you'd trim or tuck underneath, then it doesn't matter!!
Watch the youtube wrapping videos, you'll find that they all have a good few inches left over, and they are basically a huge mess of creases (wing mirror wrapping is a perfect example). But it doesn't matter, as long as you get the creases past the edge of the panel then bobs your uncle.
[Edited on 28/1/14 by Slimy38]
Proby
posted on 28/1/14 at 10:17 PM Reply With Quote
Also make sure you use a good quality cast vinyl, as it will be more workable around the curves than the cheap mono/polymeric stuff.
Chris
Visit GraphicMonster
Daf
posted on 28/1/14 at 10:25 PM Reply With Quote
I found putting the heat gun in the vice worked quite well. Then you have two hands to work the part and you can move it up to the heat gun when required
