corrado vr6
| posted on 1/2/14 at 08:33 PM |
HI Spec rear calipers ***for sale***
For sale a pair of Hi Spec rear calipers with manual cable operated handbrake mechanism (no cable supplied)
Never used!!
These also include a set of red stuff pads
These are for 10mm discs
Looking for £270
Postage will be £10
Or based in Winchester for collection
[Edited on 1/2/14 by corrado vr6]
http://r1indy7.wordpress.com/
omega0684
| posted on 1/2/14 at 11:15 PM |
do these fit the cosworth rear hub?
corrado vr6
| posted on 1/2/14 at 11:21 PM |
I can't help there I'm afraid, I wouldn't want to give bad advice so ill have to be honest and say all I know is they are suited for
seirra.
I can take more photos and take measurements if that'll help?
omega0684
| posted on 1/2/14 at 11:52 PM |
Do you have then part number that way I can check on the hi spec website
corrado vr6
| posted on 1/2/14 at 11:55 PM |
Ill take a look tomorrow as they are out my lock up and report back
omega0684
| posted on 2/2/14 at 09:09 AM |
thanks mate, 1st dibs if they fit
peter030371
| posted on 2/2/14 at 10:23 AM |
What piston size are they? If they are 38.6mm then 2nd dibs
corrado vr6
| posted on 2/2/14 at 11:51 AM |
Ok so I've had a look, I believe from what I can make out it says
Ultralite 2 SVA seirra on the box 10mm discs job number 1144
From googling I would believe this was them
http://www.hispecbrake.co.uk/ULSIESVA.html
Please don't hold me to this but I think these are them
They pistons measure approx using a metal rule 38mm
So I would assume 38.6mm
Hope this helps
peter030371
| posted on 2/2/14 at 12:41 PM |
omega064 has first dibs but if he doesn't want them I will have them
corrado vr6
| posted on 2/2/14 at 01:56 PM |
Okey doke, I'll see what's said and let you know
