Author: Subject: Rally design quick rack
Rob55
posted on 2/2/14 at 03:56 PM Reply With Quote
Can the steering ball joints be removed from the rally design rack? Looking to add lock stops and cannot find 2 piece collars that will fit, so looking to see if the rack can be dismantled easily and one piece collars added.
theprisioner
posted on 2/2/14 at 04:02 PM Reply With Quote
RS Components?
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
Rob55
posted on 2/2/14 at 04:47 PM Reply With Quote
The outside diameter of the 2 piece collars seems to be too big from what I can see
theprisioner
posted on 2/2/14 at 05:35 PM Reply With Quote
What size is your column?
Rob55
posted on 2/2/14 at 05:47 PM Reply With Quote
The rack is 21mm OD and the assembly it goes inside is 39mm ID. I can't get a 21mm collar to fit under that unless it is 1 piece with a grub screw
theprisioner
posted on 2/2/14 at 07:52 PM Reply With Quote
This is what I was advised to get:
http://uk.rs-online.com/web/p/collars/6931985/
I never actually ordered it as in the end did not need it. I believe this can be fettled to fit your application. It depends how accurate your measurements are. The 20mm can be opened up to 21mm by Black-Decker-X34036-Flap-Wheel-Medium-20mm-x-20mm. Bear in mind these devices are deliberately slightly oval to make them clamp. The 39mm can be obtained with a lathe. Again depends on how accurate your 39mm has been measured. But putting that device in a lathe and taking 1mm of is very easy.
I hope this helps.
43655
posted on 2/2/14 at 08:05 PM Reply With Quote
surely they come apart don't they? I'll have to extend my rack so i need it to!
I'm sure i read about it before in a build thread
theprisioner
posted on 2/2/14 at 08:28 PM Reply With Quote
sorry: http://uk.rs-online.com/web/p/collars/6932039/
Rob55
posted on 3/2/14 at 08:03 AM Reply With Quote
Please believe me, these are not going to be any use. The OD of the coupling is 40mm but the total clearance of the lug bolts is about 48mm.
So can anyone shed any light on whether the Rally Design rack can be dismantled?
theprisioner
posted on 3/2/14 at 09:10 AM Reply With Quote
Show me a picture please?
DW100
posted on 3/2/14 at 01:46 PM Reply With Quote
Yes you can dismantle Mk11 escort steering racks if you know what you are doing. The cups on the end are held on by a lock nut and possibly a lock pin too. Inside is a plastic cup and a tension spring. When re-assembling you need to adjust the outer cup and locknut to set the right pre-tension on the track rod then drill and fit a lock pin.
steve m
posted on 3/2/14 at 07:16 PM Reply With Quote
Unless I am misunderstanding the orig question
most people stick jubilee clips over the rack to reduce the overall rack movement ?
