Author: Subject: Where to buy carbon sheet
Matt21
posted on 2/2/14 at 08:01 PM Reply With Quote
Where is a cheap place to buy flat carbon sheet?
1.5mm will do
I need 110x45cm
thanks
40inches
posted on 2/2/14 at 08:26 PM Reply With Quote
I was looking for ages, but gave up. Something that size could be over £100
fesycresy
posted on 2/2/14 at 09:44 PM Reply With Quote
Try Carbon Mods.
Depending on what you want it for, it may be better to get 200 gram carbon faces with an E glass core.
Matt21
posted on 2/2/14 at 10:08 PM Reply With Quote
i went to a local place and they found me a sheet of 2mm 'overcured' sheet (means it wasnt made perfectly) it was about 4x4ft and they wanted £215?!?!?!?!
ill have a look at carbon mods now
the laminate stuff would be fine
Jamesc
posted on 2/2/14 at 10:10 PM Reply With Quote
I may be able to help, depending on what you need it for and how quickly you need it? That is quite a large piece.
Drop me a message if you like!
Matt21
posted on 2/2/14 at 10:18 PM Reply With Quote
message sent
I may try ringing a few other companies to find a damaged sheet or something with imperfections in it, hopefully they will be cheaper
thefreak
posted on 2/2/14 at 10:41 PM Reply With Quote
DIY?
Big mirror, a kit from carbonmods, and layer it with FG and you'll be sorted.
I picked up a sliding wardrobe with mirror from B&Q for a tenner. Just need to get round to getting the rest of the bits
big-vee-twin
posted on 2/2/14 at 11:13 PM Reply With Quote
Fluke Motorsport sell carbon bits for 7s.
http://www.triangleltd.com
yellowcab
posted on 3/2/14 at 08:30 AM Reply With Quote
Considering a rear bootlid/ panel (on an MK Indy) measures 102cm x 45cm I'm guessing thats what he's after.
Julian Eisel @ Aerodynamics supplies these
Autoflock Motorsport
posted on 12/3/14 at 01:07 PM Reply With Quote
I could knock an infused panel up for you 1000 x 500 x 2mm which would be as close to a pre-preg part in terms of resin/fabric ratio for £100.00 delivered if thats any use?
As said above carbonmods do diy wet lay kits which would be suffice but the finish and strength would be no comparison to an infused or p/p part.
Hope this helps
Kind regards
Raj
http://www.locostbuilders.co.uk/forum/23/viewthread.php?tid=183445
Matt21
posted on 12/3/14 at 05:57 PM Reply With Quote
Thanks for the reply
I have already re-made the boot lid with some carbon look abs sheet unfortunately
I think 1000mm would be just slightly too short too!
Thanks though, will keep you in mind if I need any in the future
