<<  1    2  >>
Author: Subject: Supercharged Duratec Build
Mr C
posted on 9/2/14 at 05:40 PM Reply With Quote
Just a quick post of a few images of the engine I've been messing about with since December, quite pleased with the end result thought I'd share my second "proper" engine rebuild (the first was an impreza turbo lump).
Its a supercharged 2.0 duratec from a ST150. Briefly spec is:
Raceline sump
Cosworth Pistons
Williams Motorsport Forged Rods
Newman Cams (278) and heavy duty springs and matching retainers
R300 Plenum, 70mm throttle body
Rotrex C30-94 blower
Still awaiting a few bits, alternator, fuel rail etc though as good as completed, matching it to a 6 speed Maxda 3 MPS box for installation into a "Midlana" chassis
A before with an after..
A couple of arty shots...
One more after..
Hping it'll go as well as it looks..
[Edited on 9/2/14 by Mr C]
Girl walks into a bar and asks for a double entendre, so the barman gave her one
big_wasa
posted on 9/2/14 at 06:08 PM Reply With Quote
Looks very nice. Have you started the Midlana chassis yet ?
Any links to the Scooby rebuild ?
[Edited on 9/2/14 by big_wasa]
Mr C
posted on 9/2/14 at 06:29 PM Reply With Quote
Afraid not Wasa, I posted the build on Kent Scoobies, unfortunately the site is no more, image below as a consolation..
If you are thinking of rebuilding one, they are not too bad, splitting the crankcase is a PITA and a bit costly on parts compared with the Duratec. When it fired up it was a sweet moment though..
Next step is build the chassis table and start on the chassis
TrophyJem
posted on 9/2/14 at 06:42 PM Reply With Quote
That looks proper nice. What paint did you use on the block and cam cover?
Mr C
posted on 9/2/14 at 07:02 PM Reply With Quote
Etch primer and VHT engine enamel on the block, VHT crinkle paint on the covers. I normally use Simoniz alloy wheel paint and lacquer with etch primer for an alloy finish on engines. Its fine with the heat and gives a good alloy look "Steel wheels" colour rather than "silver wheels" which is too bright ( at least I think its that way round)
big_wasa
even nicer
Are you planning on bending the cage your self or getting it done ? That and a few other toys are slowing me up starting the Midlana.
Mr C
posted on 9/2/14 at 07:07 PM Reply With Quote
even nicer
Depends on how I decide to construct it, currently looking at making the chassis out of box with a bolt on cage,.. though thats for another thread I have started a build thread on the Midlana forum though not a great deal on it currently.
jeffw
posted on 9/2/14 at 07:14 PM Reply With Quote
Mike
Has anyone else ever used the R300 plenum for boosted applications?
Mr C
posted on 9/2/14 at 07:44 PM Reply With Quote
Originally posted by jeffw
Mike
Not that I know of Jeff, probably because they don't come up for sale that often and it wouldn't be suitable in most applications (RWD) because of the rearward facing throttle body. I don't have an issue with this as the intercooler will sit at that end over the gearbox because its going in a transverse package. The only downside I can see are the core plugs potentially blowing out, though 1 bar isn't huge boost in the scheme of things, so they should be ok, if not I'll get new plugs tigged in or throw it way and get another one.
jeffw
posted on 9/2/14 at 07:46 PM Reply With Quote
It would be interesting to pressure test it....It looks like it is in two parts?
Mr C
posted on 9/2/14 at 08:08 PM Reply With Quote
One part, its solid Jeff, "moulding lines" between the top and bottom.
big_wasa
posted on 9/2/14 at 08:12 PM Reply With Quote
It would be great if some one started supplying bits like the cage tubes and laser cut plates. I did the make everything with the locost.
ceebmoj
posted on 9/2/14 at 10:56 PM Reply With Quote
What did you use to clean the block?
SilverFox
posted on 10/2/14 at 03:12 AM Reply With Quote
Who makes that nice looking dual idler pulley bracket?
jeffw
posted on 10/2/14 at 06:18 AM Reply With Quote
I presume it will be TTS
http://www.tts-performance.co.uk/#!ford-duratec-/c1amx
Mr C
posted on 10/2/14 at 09:13 AM Reply With Quote
As Jeff mentioned TTS make the supercharger kit.
There's no easy way to clean the block. I do an initial gunking then use brake / clutch cleaner to degrease. I also use alloy wheel cleaner (halfords cheap brand) and have used oven cleaner thoughit is very aggressive. A few wire brushes and a drill come in handy. Or you could drop it off at an engine specialist who will clean it for you.
SilverFox
posted on 10/2/14 at 08:34 PM Reply With Quote
Thanks guys, that is a neat bit of kit - I guess the dual idler arrangement could also be used in a conventional belt arrangement - your engine choice looks brilliant. Look forward to the MidLana install
Mr C
posted on 10/2/14 at 09:42 PM Reply With Quote
Thanks all and thanks Silverfox for the compliments. Using the billet idler arrangement is an expensive way of routing the belt if you are not fitting a supercharger. The most cost effective way is to use the standard idler wheels which fit with a single bolt to ensure the belt wraps around the various drive pulleys adequately.
SilverFox
posted on 11/2/14 at 02:37 AM Reply With Quote
I am in the process of assessing the best approach for idler and tensioner issue - you probably right. I have two issues, the first being the Ranger front cover has the "conical hump" for the fan pulley, which might interfere with path of the belt. The other is the interference between the tensioner (same as yours) and the TPS on the throttle bodies (modified GSXR).
But we'll get there.....
peter030371
posted on 11/2/14 at 08:42 AM Reply With Quote
I The other is the interference between the tensioner (same as yours) and the TPS on the throttle bodies (modified GSXR).
I am in the same position as you....Cosworth do a modified pulley ,click here, but having never seen one or exactly what/ how they modify it then I am loathed to potentially waste £45
My current plan, unless someone can tell me the Cosworth item fits with GSXR TB, is to have a fixed pulley in the same position and make the alternator manually adjustable....is that a bad idea?
SilverFox
posted on 11/2/14 at 10:28 PM Reply With Quote
Thanks for link. Not so sure that Cosworth tensioner will help, but hard to tell from pictures. It seems to be as deep as the stock Ford.
I too am looking at the two options for tensioning either via the alternator mount located on the RHS (below headers) or making a bespoke adjusting bracket for a normal pulley located in place of the proper pulley (in front of TB's). My TPS is a little larger, as I took forum advice to not use the GSXR TPS which apparently performs more like a switch making MS tuning difficult, and adapt a progressive automotive TPS
peter030371
posted on 24/2/14 at 02:50 PM Reply With Quote
I don't often open the bonnet of my tintop (mazda 5) but the washer bottle was empty.....whilst doing that I noticed that the Mazda pulley tensioner is a lot smaller than the standard ford item. A few minutes on ebay and I had found this Alternator Belt Tensioner Pulley Mazda 5/3 Gates T38357 | eBay
Its better than the Ford one but even so holding my GSXR bodies up to the Duratec in the workshop its still tight.....not sure I want to send £38 to find its still too big
SilverFox
posted on 24/2/14 at 07:36 PM Reply With Quote
Thanks for the link. That Mazda tensioner may have potential, as I note that the rear of the spring casting is almost in-line with the two upper/lower bolt holes. I need to snow shovel my out to the shop to refresh my memory on how the stock Ford compares in that regard....may take a while!
itsawindupuk
posted on 28/2/14 at 12:17 PM Reply With Quote
I like the exhaust manifold, do you know the diameter of the primaries?
Mr C
posted on 2/3/14 at 10:26 PM Reply With Quote
Its a cheapie off the bay probably won't last long, as they hava a tendancy to crack. it'll do until I get the car built and IVA'd, then I'll sort another one out if its no good. The primaries are 43mm OD
<<  1    2  >>
