AntonUK
| posted on 17/2/14 at 11:09 PM |
Coilover Rebuild
Hi All,
Given I appears that im rebuilding nearly everything on my car before it see's the tarmac again. I'm looking to get my coilovers
refurbed.
I can see through a very faded sticker that the original manufacturer was SPAX.
Any recommendations for good service at reasonable rates?
Build Photos Here
Dingz
| posted on 18/2/14 at 07:48 AM |
Try Spax for a start? They have been going for a long time.
went on and on.
MikeCapon
| posted on 18/2/14 at 07:55 AM |
You need to see which model Spax you have. The cheapest (and most common) versions are peened shut and are hence pretty much impossible to rebuild.
Equally the rods are welded to the top eyes making changing a poorly rod more than awkward.
Look at the top of the body where the rod goes in. If you can see the slightly rounded edge where the metal of the body has been folded down to close
the shock then you have two choices. Use as is or bin.
Good opportunity to swap to some decent shocks such as ProTech....
www.shock-factory.co.uk
FuryRebuild
| posted on 18/2/14 at 01:04 PM |
I went for Gaz instead, supplied by Cornering Force.
Not much more than spax for a much better shock than the entry-level one I had on my Fury.
Hope this helps
Mark
www.furyrebuild.co.uk
AntonUK
| posted on 22/2/14 at 05:59 PM |
Ive had a look, and it looks like the top of the body (at the rod exit end) has a threaded cap... Sounds like its possible?
Anyone have an idea how much I should expect to pay for a rebuild?
Build Photos Here
MikeCapon
| posted on 23/2/14 at 12:58 PM |
Sounds like it may well be possible. Is there also a locknut under the top eye? Expect to pay around £50 per unit for a proper rebuild. Kee a close
eye on the price as you'll not need to find many extras (rod replacement for example) before you could be better off buying new. For example:
ProTech
AntonUK
| posted on 23/2/14 at 11:12 PM |
Yes there is... I'll get some photos tomorrow.
Thanks for your help
Build Photos Here
