Author: Subject: Best way to cut clear Perspex ?
Jon Ison
posted on 18/2/14 at 05:40 PM Reply With Quote
I don't own a jigsaw, slitting disc too much, will it burn and discolour it?
theprisioner
posted on 18/2/14 at 05:57 PM Reply With Quote
I am told these are the type to use by a man from Brasscraft example:ebay item: 131098266297
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
TallGuySmallBike
posted on 18/2/14 at 06:28 PM Reply With Quote
A hammer.
posted on 18/2/14 at 07:02 PM Reply With Quote
For sheets up to about 3-4mm you can cut straight lines by deeply scoring the sheet with a stanely knife and snapping it across the edge of your workbench.
Circular and jigsaws can be used, but both tend to melt the edge which can partially weld itself back together. A hand saw designed for wood works perfectly well, you just need to clamp the sheet down firmly close to the cut line and use a shallow angle on the saw (this is they way my old woodwork teacher taught us). If you make a short cut from the opposite end and side first then you won't get a chip taken out of the corner as you complete the cut.
File/sand the edge to remove the saw marks and then run the flame from a blowlamp across it to get a perfect glossy edge.
[Edited on 18/2/14 by MikeRJ]
waggy
posted on 18/2/14 at 08:32 PM Reply With Quote
What mike said.
Almost to the letter what I was going to say.
Don't go too mad with the flame it only takes a quick lick.
Do the right thing, right, first time!
If only it was that simple!
austin man
posted on 18/2/14 at 09:30 PM Reply With Quote
if using a jigsaw etc I use a compressor to blow away swarf and cool the blade this prevents the welding back together
Jon Ison
posted on 18/2/14 at 10:10 PM Reply With Quote
Looks like I need to invest in a jigsaw ?
adithorp
posted on 18/2/14 at 10:49 PM Reply With Quote
I've always done it with a jig saw. Recently invested in a battery one and it's a lot easier to use than the old mains one dragging the cable along.
http://jpsc.org.uk/forum/
unijacko67
posted on 18/2/14 at 11:29 PM Reply With Quote
244D bosch blades, slow speed, firm grip, press on.
whatever type/make of jigsaw you get try for bosch blades as they are the best.
I used plunge saw for all the straight bits for the sliders and finished all the corners with jigsaw. As mentioned you do need to get the speed/pressure right or it welds back up behind you.
http://www.kittenkitcar.co.uk
posted on 18/2/14 at 11:47 PM Reply With Quote
The jigsaw I use runs so slow you can count the strokes, my old one used to melt the edges back together with a fine tooth metal blade.
Matt21
posted on 17/3/14 at 08:45 AM Reply With Quote
i couldnt survive without my jig saw! gets lots of use!
also inves tin some G clamps if you dont have already, then clamp a straight edge to the perspex to run the jigsaw along for your perfect straight cut (if you're a spacker like me and cant cut straight then its great )
Jon Ison
posted on 17/3/14 at 09:07 AM Reply With Quote
update, I cut it with a very slim slitting disc in my angry grinder, clean as a whistle no melting job done.
trextr7monkey
posted on 17/3/14 at 11:41 AM Reply With Quote
Bandsaw, no problem
coyoteboy
posted on 30/3/14 at 07:47 AM Reply With Quote
Router works too.
Proby
posted on 30/3/14 at 09:21 AM Reply With Quote
I watched someone use an industrial guillotine the other day thats usually used for aluminum sheet. I awaited the crack and was shocked at how well it worked cutting the perspex sheet.
Visit GraphicMonster
40inches
posted on 30/3/14 at 09:36 AM Reply With Quote
Are you sure it wasn't Polycarbonate?
