Author: Subject: flatshifter fitting
daniel mason
posted on 23/3/14 at 09:30 PM Reply With Quote
flatshifter fitting
am struggling fitting the actuator to my car as there just isnt enough travel on the gear selector arm for it to work correctly! can you buy an extended arm? or is it just a case of bolting on something to extend it to give it more travel? cheers
Matt21
posted on 24/3/14 at 07:13 AM Reply With Quote
can you fit it closer to the pivot point?
that will mean you need less travel
daniel mason
posted on 24/3/14 at 07:16 AM Reply With Quote
it needs moving further away!
the rod on the actuator has 1" travel either direction (up/downshift) and needs to ust the full amount. i currently have around 1/2" travel and it wont work correctly. i can either get it to a position where i get only upshifts or only downshifts but not both! cheers
40inches
posted on 24/3/14 at 08:41 AM Reply With Quote
I had the same problem with the Kliktonic, that needed 25mm each way. I bolted a strip along the gear lever to give
enough movement. It used the last hole in this pic. The lever is a Pit Bike one from ebay, about £8.
[Edited on 24-3-14 by 40inches]
grazo
posted on 18/4/14 at 04:56 PM Reply With Quote
Flatshifter
If you use the standard gear selector arm with the shorter than 25mm of travel you will overload the actuator and possibly burn it out, as the load required to change gear will be considerably higher.
