Author: Subject: Fireblade with no spark 919
Nurburg2006
posted on 12/4/14 at 09:32 AM Reply With Quote
Hello guys I've still not got a spark on the blade engine, I've not got any power down the pulse side or the tps side got earths but that's it the ecu has some live and some earths. There is a grey wire which is connected to a clutch diode which goes to the side stand and earthed I've got power to the coils and that's it, there is no pink wire to the ecu. Any help would be good
Doctor Derek Doctors
posted on 12/4/14 at 09:44 AM Reply With Quote
Have you got the coil packs wired up correctly? Do you want me to take a picture of mine and e-mail it to you?
Also are you sure that there isn't a pink wire? It's an immobiliser and needs to be hooked to love with a correct valid resistor.
www.t89.co.uk
www.racecarwings.co.uk
callan@t89.co.uk
Nurburg2006
posted on 12/4/14 at 09:47 AM Reply With Quote
Any help would be good. 12 wires to my ecu
minitici
posted on 12/4/14 at 12:15 PM Reply With Quote
Assuming you are not using the Honda keyswitch, then most likely you don't have a 100 ohm drop resistor in your VC line to the ICM.
The wire to the ICM should be pink.
wiring
wiring
Nurburg2006
posted on 12/4/14 at 03:20 PM Reply With Quote
I haven't got a pink wire on my ecu
minitici
posted on 12/4/14 at 03:25 PM Reply With Quote
In that case have you looked at all the 12 wires on your ecu and checked if 11 of them concur with the diagram above.
If so the 12th wire is likely to be the 'pink' wire????
Nurburg2006
posted on 12/4/14 at 03:57 PM Reply With Quote
Could this be the problem the coil wire are bridged with a +supply that's why they have power should there be the resistor in this line?
minitici
posted on 12/4/14 at 04:22 PM Reply With Quote
Coils should have a +12V feed which should be common to the run/stop ignition switch feed (it does not have the resistor fitted as this needs the full +12V).
IainL
posted on 12/4/14 at 06:13 PM Reply With Quote
As promised I've uploaded a couple of photo and also left you a couple of U2U's
If all else fails give Andy Bates a call at AB Performance he'll give you loads of advice
Iain
IainL
posted on 14/4/14 at 05:48 PM Reply With Quote
Have you got it sorted yet?
Nurburg2006
posted on 14/4/14 at 06:34 PM Reply With Quote
Not yet
jossey
posted on 14/4/14 at 06:45 PM Reply With Quote
have you got any volts to the coils?
David Johnson
Nurburg2006
posted on 14/4/14 at 06:52 PM Reply With Quote
Yes there is power there
dave_424
posted on 14/4/14 at 06:59 PM Reply With Quote
So you have power to the coils, but the ecu isn't grounding them to give you your spark. Is the loom the same as it was in the bike or is it cut/extended etc?
All the ignition cutouts i've seen are clutch switch if you are starting in gear, sidestand switch and tip over sensor. You say that you have grounded one of the switches, what I would do would be to see if the switch opens or closes the circuit in the run position and then if it closes the circuit in the run position (more than likely) then connect the two wires running to the switch. You might not be correct in thinking that the wire has to be earthed, it might have to connect to the other wire with it.
Dave
Nurburg2006
posted on 14/4/14 at 09:10 PM Reply With Quote
Hay guys had a quick play tonight went back over everything put new terminals on everywhere and hay presto I have a spark and a engine that fired up cheers for everyone's advice. Cheers
