New Topic New Reply
Author: Subject: Curve in wishbone plate
Slimy38
posted on 18/4/14 at 05:35 PM Reply With Quote
Just a quick question, what's the reasoning behind the curve in the wishbone plate? Does it actually do something or is it decorative? My plates are currently straight edged from one side to the other.
I noticed Talon's MX5 wishbones replace the curve with a horizontal bar;
although he keeps the curve in for the Sierra wishbones;
jacko
posted on 18/4/14 at 05:40 PM Reply With Quote
I seem to remember reading if straight it puts strain on the tubing
Jacko
Slimy38
posted on 18/4/14 at 06:00 PM Reply With Quote
Jacko
Seems reasonable. If I simply cut a curve out of the plate now that the wishbones have been made up, will that suffice? Is there any 'golden rule' as to how much of a curve is required?
I've just been reading the 'bent wishbone' thread, British Trident talks about dressing the welds to prevent any sharp corners, should I do that at the same time?
twybrow
posted on 18/4/14 at 06:45 PM Reply With Quote
I am not a stress engineer, so can't help on rules off the top of my head, but it is all about reducing stress concentrations where the two pieces meet. A sharp corner will typically give you a stress concentration, whereas dressed welds, and a curve to the joint will help to reduce this... I wonder also if Talon does this to reduce weight too?
mark chandler
posted on 18/4/14 at 06:59 PM Reply With Quote
Curve reduces the stress point, you should also weld in the middle of the tubing not top or bottom.
Slimy38
posted on 18/4/14 at 08:22 PM Reply With Quote
Yep, already done that bit even if it was a complete pain to get everything fitting perfectly!
coyoteboy
posted on 18/4/14 at 08:36 PM Reply With Quote
Curved gussets spread the load down the weld more evenly rather than concentrating at a point.
PhillipM
posted on 27/4/14 at 11:47 AM Reply With Quote
Welding a brace/gusset to the middle of the tube makes the stress even worse, it really should be almost flush with the top/bottom of the tubes, the middle of the tube is the weakest, least stiff part as far as a gusset is concerned. That's why when you see gussets on rollcages they're generally two pieces rolled around and welded either side.
Slimy38
posted on 27/4/14 at 12:18 PM Reply With Quote
Mmm, I have to admit that's the first time anyone has suggested that, and the only time I've seen plate welded to the top or bottom was on the 'bent wishbone' thread which certainly isn't the best example.
Even a quick google image search for rollcage gussets shows both being used, although it does appear that the top/bottom gussets are much thinner metal than the centre gussets.
Would anyone else care to weigh in?
PhillipM
posted on 27/4/14 at 12:36 PM Reply With Quote
If you weld them in the centre your putting the stress into just the wall thickness of the tube - running the risk of kinking the tube (and hence a big loss of strength) with an impact, and cracking with fatigue if the ends off the gusset aren't rounded and ground flush.
If you weld them on the outside you're effectively using about a quarter of the tubes diameter as the effective wall thickness.
[Edited on 27/4/14 by PhillipM]
Slimy38
posted on 27/4/14 at 02:03 PM Reply With Quote
But conversely, if the gusset is on the top (which would be the most likely due to it being a suspension wishbone), you've got the weight of the car (and the suspension) trying to do the same thing in a vertical plane. And suspension forces are guaranteed whereas an impact is (hopefully!) unlikely.
I do see your point, but for now I'll stick with the Haynes manual design.
posted on 27/4/14 at 02:19 PM Reply With Quote
A roll cage is an entirely different load case, if look back 10+ years to the early days of as per book Locost building you will find horror stories of bent wishbones, after a bit of discussion among the group a consensus was reached that welding a plate with nicely tapered ends along the neutral axis of the wishbonebtubes was a valid solution.
Experience has shown that it works as stories of catastrophic failures in wishbones are pretty rare these days although there are a lot more cars on the road..
garyt
posted on 27/4/14 at 02:58 PM Reply With Quote
Hi if your after the plates.. I just copied the drawings to craig at plazcut waiting for costing to do the mx5 wishbone plates if anyones interested will post it when I get a reply
Gaz
PhillipM
posted on 27/4/14 at 08:48 PM Reply With Quote
Yes, but if you're putting a vertical load through a flat, horizontal plate and expecting it to be stiff, you've got more issues than welding it to the wishbone...
The very reason those talons ones you pictured have had to fit a horizontal bar is to spread the load to the top and bottom of the tube to stop the gusset kinking/cracking the main tubes in the centre.
[Edited on 28/4/14 by PhillipM]
Samuele
posted on 3/6/16 at 10:24 AM Reply With Quote
s
New Topic New Reply
