Author: Subject: Plastic Tube?
AntonUK
posted on 1/5/14 at 08:19 PM Reply With Quote
Plastic Tube?
I need to make a wiper wheelbox spacer with slightly different dimensions than a standard item.
So what I'm in need of is some plastic tube (black preferably) 16mm (5/8" I/D 5mm wall.. need only a 60mm length... Any ideas where I could get some?
My best option atm is to buy some Acetal rod and drill it out to suit.
Build Photos Here
Alan B
posted on 1/5/14 at 09:14 PM Reply With Quote
I'm not sure of the availability of such relatively thick wall tubing, so I'd be inclined to go for option B assuming you have a lathe available, it's a ten minute job.
Alan
AntonUK
posted on 1/5/14 at 09:39 PM Reply With Quote
No lathe unfortunately... will be a careful bit of work on the pillar drill.
Build Photos Here
bi22le
posted on 1/5/14 at 11:07 PM Reply With Quote
Yup option b if you want plastic. If you can find it you will have to probably buy 1 metre worth.
Please read my ring story:
